Case swap?
Go to solution Solved by LienusLateTips,
Define C TG? Meshify C? S340 Elite? Define R4?
I have an Enthoo Primo that I was kind of disappointed about. I got it used for 40 but it was pretty scratched up and on a scale of 'Like new' to 'Poor' I'd say it was somewhere between Fair and Poor. It constantly rattled and most of the accessories where missing as well. I'm looking to downsize to an ATX mid tower that can also support water cooling in the future. I was thinking of the H440 but it's kind of an old case now (the second revision came out in early 2015). Here's my current upgrade list for 2018 https://pcpartpicker.com/list/GZ4j8K . What cases would you reccomend for me to switch to? My budget is about 130 dollars for the case alone.
https://linustechtips.com/topic/880308-case-swap/
Just now, Oberon.Smite said:
I have an Enthoo Primo that I was kind of disappointed about. I got it used for 40 but it was pretty scratched up and on a scale of 'Like new' to 'Poor' I'd say it was somewhere between Fair and Poor. It constantly rattled and most of the accessories where missing as well. I'm looking to downsize to an ATX mid tower that can also support water cooling in the future. I was thinking of the H440 but it's kind of an old case now (the second revision came out in early 2015). Here's my current upgrade list for 2018 https://pcpartpicker.com/list/GZ4j8K . What cases would you recommend for me to switch to? My budget is about 130 dollars for the case alone.
https://linustechtips.com/topic/880308-case-swap/#findComment-10884171
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/880308-case-swap/#findComment-10884179
R6*
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/880308-case-swap/#findComment-10884183
