SSD help
Colin Donoghue
depends upon your workload. If you're with professional Video Editing or any other pro workflows, go for NVMe based drives. Otherwise SATA based is fine.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
does your motherboard have an m.2 slot ? if not is it worth getting an expanion card ?
sata ssd runs fine 400+ read/writes
m.2 will yield reads in excess of 2000+
Go for the SATA SSD. NVMe isn't really worth it for most use cases, and more storage is beneficial.
If you were going to spend more and the size was the same, or they were both 1TB drives, it'd be a different story.
M.2 has nothing to do with speed, it's a connection type...
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
yeah and that connection type gives you much greater read write speeds .......
No, it doesn't. NVME gives you much greater speeds. M.2 can also be SATA, which is exactly the same as a regular SATA SSD.
