I currently have windows 8.1 pro installed on my computer, but because it is a cloned copy, it is no longer activated. The other storage devices is in use in another computer so using it wouldn't be an option. My only choices now would be to buy a licence for windows 8 or you know...Can't stand that "Activated Windows now" B.S anymore.
Options
1) buy this, http://www.newegg.com/Product/Product.aspx?Item=N82E16832416779, Problem is that I don't know if the key will work in activating windows 8.1 pro or if it is only for an upgrade to windows 8.1 pro...which is what i have installed.
2)Use the re-installation disc that came with my laptop about 4 years ago and buy this, http://www.microsoftstore.com/store/msusa/en_US/pdp/productID.264954100 , my windows 7 will have the build error but i know it works cause it is what i origally did when i got windows 8 pro for $15 bucks *now 70*. but even though it's cheaper I'm just too lazy....
Anyway, anyone know if the product upgrade key from newegg will work? It'll save me the hassle. Unless anyone has a windows 8.1 pro key they don't want.
https://linustechtips.com/topic/87874-81-product-code/
If you are in college or university usually on campus book stores have windows 8 copies for dirt cheap (Got mine for $11 USD) Just buy it legit worth the money BUT DON'T BUY OEM buy a retail version
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/87874-81-product-code/#findComment-1191080
Campus book stores...cheap..I don't know about that. Last exam is tommorow but I guess I'll go see if they have copies
https://linustechtips.com/topic/87874-81-product-code/#findComment-1191090
It's easy enough to activate Windows with an upgrade key, so go for it if that's the cheapest you can get it.
Intel Core i7-7700K | EVGA GeForce GTX 1080 FTW | ASUS ROG Strix Z270G Gaming | 32GB G-Skill TridentZ RGB DDR4-3200 | Corsair AX860i
Cooler Master MasterCase Pro 3 Samsung 950 Pro 256GB | Samsung 850 Evo 1TB | EKWB Custom Loop | Noctua NF-F12(x4)/NF-A14 LTT Special Edition
Dell S2716DGR | Corsair K95 RGB Platinum (Cherry MX Brown) | Logitech G502 Proteus Spectrum | FiiO E17 DAC/Amp | Beyerdynamic DT990 Pro
https://linustechtips.com/topic/87874-81-product-code/#findComment-1191100
Yeah at the U of M OS's and software/programs are super cheap. Maybe that's just the US or certain college's but I doubt that.
OS - Windows 8.1 Motherboard - ASUS M5A99FX Pro R2.0 Processor - AMD FX 8350 Black Edition RAM - 16GB 2x8 Crucial Ballistix Sport Graphics Card - Gigabyte Windforce 2 OC GTX 660 Power Supply - Corsair CX750M CPU Cooler - NZXT Kraken X60 Wireless Adapter - ASUS PCE-N15 PCI-E Adapter Fans - x3 Masscool blue LED 120mm Fans Case - Fractal Design Define R4
Monitor - Dell S2230MX 21.5-inch Keyboard - Logitech G105 Mouse - Logitech G602 Speakers - Logitech Z130 Headsets/Headphones - Tt eSports Shock, AKG K240, California Headphones Laredo Phone - iPhone 4S
https://linustechtips.com/topic/87874-81-product-code/#findComment-1191103
But will the upgrade work if I'm buying an upgrade key for something I have?
Pretty sure.  You basically just put in the key in Windows, change a registry value, restart, and you're done.  You don't need to reinstall or anything.
Also, I'm assuming you don't have access to Dreamspark?  Maybe you can figure out how to get access from your school's IT department or something.
https://linustechtips.com/topic/87874-81-product-code/#findComment-1191115
Funny you should mention dreamspark. Signed up for it like 2 weeks ago..buy nothing on thier software catalog interest me yet.
https://linustechtips.com/topic/87874-81-product-code/#findComment-1191132
Wait, you don't get free Windows from Dreamspark?  Hmm, I guess your school doesn't have the full subscription package or something.
https://linustechtips.com/topic/87874-81-product-code/#findComment-1191143
You should be able to activate it since it says it needs windows 8.1:
SYSTEM REQUIREMENTS
If you were running Windows 8.1, your PC will restart automatically and Windows 8.1 Pro with Media Center will be available for use.
To install Windows 8.1 Pro Pack, you must be running Windows 8.1. Internet access fees may apply. Prices shown are estimated retail prices; actual price may vary. Additional hardware may be required to watch and record live TV with Windows Media Center. If you purchase a new PC with an addition of Windows 8.1 preinstalled and you later upgrade that PC with Windows 8.1 Pro Pack, Windows 8 Media Center Pack, a volume license edition, or a retail edition, you will no longer be able to install apps that are provided exclusively from your PC manufacturer through the Windows Store.
See if you can search your school here: https://www.dreamspark.com/Student/default.aspx
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/87874-81-product-code/#findComment-1191192
Already signed up for it, Only question is what is the difference between windows 8.1 industry pro embedded and regular windows 8.1 pro?
https://linustechtips.com/topic/87874-81-product-code/#findComment-1191206
Why not buy OEM? It's way cheaper and exactly the same.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/87874-81-product-code/#findComment-1191207
If you replace motherboard and/or cpu you can reuse the windows key
Hope I could help!
https://linustechtips.com/topic/87874-81-product-code/#findComment-1191224
So your using the drive but are you using the os on the drive if not boot to it and deactivate it and the reactivate it on this new pc.
https://linustechtips.com/topic/87874-81-product-code/#findComment-1191234
Examples of such features supported by the Enterprise edition include things like AppLocker for application lock-down, which prevents end users from installing some software on devices. Another Enterprise-supported feature will be application sideloading, which is a way for organizations to push software out to end users and manage the distribution.
Microsoft's embedded OSes are a bit different from their desktop cousins. The embedded OSes don't have all of the functionality of the desktop OSes, but they do have some added capabilities specific to the specialized device world, such as keyboard, write and gesture filters.
Source: http://redmondmag.com/articles/2013/04/02/windows-embedded-8-industry.aspx
http://www.microsoft.com/windowsembedded/en-us/windows-embedded-8-pro.aspx
I would just get Regular Pro if they have it since you won't be using the features in industry pro imo because this is intended for things like ATMs and healthcare systems.
https://linustechtips.com/topic/87874-81-product-code/#findComment-1191273
You can do that with OEM keys too :) Re enter it, or just call and get it reactivated.
15" MBP TB
https://linustechtips.com/topic/87874-81-product-code/#findComment-1191292
Oh snap! My bad! I was misinformed! Thank you!
Hope I could help!
https://linustechtips.com/topic/87874-81-product-code/#findComment-1191440
both drives are being used
Thats not the issue if there both being used. The issue will be if your trying to use that one product key on two PCs. If you just closed the drive to anew one then popped it into another PC this is easily resolved. Now if you are indeed trying to use the same product key on two PCs you kinda walked into this situation.
https://linustechtips.com/topic/87874-81-product-code/#findComment-1191744
I understand that...which is why I'm trying to buy a product code.
https://linustechtips.com/topic/87874-81-product-code/#findComment-1192101
What questions do you have about buying one?
https://linustechtips.com/topic/87874-81-product-code/#findComment-1192208
