Uninstall all the bloatware from the manufacturer, had someone bring a HP to me recently with a similar issue.  Turned out to be one of the HP software packages causing it, can't recall the name of it right now though.
Please quote or tag me if you need a reply
https://linustechtips.com/topic/878360-input-lag-csgo/#findComment-10866915
was it specifik to csgo
https://linustechtips.com/topic/878360-input-lag-csgo/#findComment-10866921
