Looks like your pickings are pretty slim
https://pcpartpicker.com/products/case/#t=9,10&xcx=0&J=6,20&sort=price&page=1
I'd almost consider a small mATX enclosure, but it entirely depends on where you're trying to fit it.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/877953-mini-itx-case/#findComment-10863171
What'll be the purpose of the NAS? Just basic file storage or more?
If just basic storage, you won't need much. A Celeron or Pentium with 4gigs of RAM and a suitable operating system (FreeNAS, Windows with file sharing, Xpenology etc.) will do. If your budget stretches a little bit, you could get a C-series chipset board with a Pentium and ECC RAM.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/877953-mini-itx-case/#findComment-10864215
