Just now, Matt115 said:
I dont know how to or if I can overclock my ram. Here is my build. My pc keeps blue screening on startup. I set the ram to 2933 or something then it didnt boot, so i reset it. It is still not booting. Thanks
https://pcpartpicker.com/list/8LrVhq
You need to clear CMOS Set ram at 2133 Update the bios. And retry
CPU: Intel Core i9 9900K | Ram: 32GB Corsair LPX 3200 DDR4 | Asus Maximus XI Hero Z390 | GPU: EVGA RTX2080 XC | 960 EVO Samsung 500GB M.2 | 850 EVO Samsung 250GB M.2 | Samsung 1TB QVO SSD | 1TB HDD WD Blue
Drop memory speed to 2666 or 2400. Your chip might not like the higher speed memory at stock voltages.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
15 minutes ago, Matt115 said:
I reseated the cmos battery and ran into the same problem
Update the bios.
PC gets “server exception error” every time I start it
My new pc was going great. I tried changing the target speed on the ram in bios. Didnt work. Back to default settings. Didnt work. Ive tried clearing cmos multiple times. Is it corrupted ram and what do i do thanks.
What does "didn't work" mean? Fans not spinning up? No post?
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
you will also have to adjust the voltages and the timings for it to run at the rated speed
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
Sorry the pc got to the blue”ran into a problem screen”
2 minutes ago, Sierra Fox said:
What did the blue screen say? It would have given you a specific error message, eg "Bad_pool_caller"
Service exception
Disconnect the PSU from the power cord to the wall. Remove the RAM. Pull the CMOS battery out. Hold down on the power button for 10-12 seconds. Put the RAM back in. Make a bootable USB with MemTest86 on it (a bootable Ubuntu distro works as well, as they include MT86). Boot to MT86 and let it run overnight. If you truly do have corrupt RAM, it will start throwing errors. If you don't, it will look fine in the morning, and the CMOS reset will likely have taken care of everything.
Now, it's entirely possible that something happened to corrupt Windows. That's a different fix. If you can get into Windows, open an elevated command prompt and type:
sfc /scannow
If you can't get into Windows, you'll have to reinstall through boot media. If you set it up as an upgrade installation, it won't wipe out your files.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
1 hour ago, Matt115 said:
Pretty sure its messed up ram going to buy some more and see
Pretty sure it's AID's
Anyways, changing a setting in bios isn't likely to cook a stick of ram unless you threw some crazy voltage at it.  I would focus on ensuring your computer is running within spec before buying a new product.
edit: it is also far more likely that you corrupted your OS data with a bad clock than damaged your ram.
Audio go Brrrrrr
Have you run MemTest86 yet? It's pretty hard to randomly kill RAM unless one of the sticks was bad when you bought it, and you can save yourself the hassle of a return by using MT86 to troubleshoot.
