does it gonna work?
Go to solution Solved by suchamoneypit,
8 minutes ago, Yoandy said:
all you had to do was google the case and its the first thing I found without even specifically looking for it was radiator support.
http://www.coolermaster.com/case/full-tower/trooper/
yes it will. Shouldn't be any issues.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/877480-does-it-gonna-work/#findComment-10859333
