Define R5 doors
lorcav123
Is there a way to expand the range of Define R5 doors? Default they can only open about 90 degrees. I am asking this because my clumsy friend today almost broke my door on R5, he wasn`t careful and he softly hit door when door was open on max range (90 degrees). Luckly without any damage. It would be great if they could open to some ~180 degrees....
Double hinge it
Want to custom loop?  Ask me more if you are curious
2 hours ago, Damascus said:
Double hinge it
What?
It already set normally...
4 minutes ago, lorcav123 said:
What?
If you have 2 90 degree hinges you have a total opening radius of 180
Thanks!!
I presumme I have only one pair of hinges with R5, I will need to buy another pair of hinges
5 hours ago, lorcav123 said:
Thanks!!
Ask fractal for a set of em
