Hi,
I recently got a x299 taichi motherboard.
On the actual board, it has an 8-pin header for power to the CPU, however bundled in the box also has an 8-pin to dual 8-pin adapter.
The adaptor is using CPU layout pins, not PCIe.
I am mainly confused about whether it's required. I have checked on Asrocks website for box contents, and it's not even listed. The manual doesn't have it listed in the box contents, and a reviewer removing every piece from their box didn't have one of these either.
Do I need to use this, and if so, how/why?
Thanks in advance.
https://linustechtips.com/topic/876832-motherboard-cpu-power-question/
46 minutes ago, lttta said:
7820x with a mild overclock?
My next question is why asrock didn't just put two 8-pin connections on the motherboard.
if you are using a high end GPU (GTX 1080 and >) that two 8-pin connectors will be useful to power the Graphics Card
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
