Hello friends, I have one or several questions ... if someone can help me, I just built my own pc, I built it with the following components; I9-7920, 16GB of RAM DDR4 2400 MT / s, the motherboard is the GIGABYTE X299 UD4 2066 ATX, the graphic card is the GTX1080A STRIX 8GB, the power source is the THERMALTA 750W TOUGHPOWER GOLD RGB, the memory where the operative system is installed is a 256GB SSD SanDisk SD8SBAT-256G-1122 Z400s, 15TB of HDD, the monitor is the ASUS ROG SWIFT PG258Q 24.5 "Full HD 1ms 240Hz ...
Actually I'm not a professional but it's the first time I build my own PC, I've seen many videos of this forum, "Linus Tech Tips," I had always wanted a computer like that and had my chance to do it in my own way , but I must say that it was not as easy as I thought, to start describing my problems, I saw a video where you describe the monitor ASUS ROG SWIFT PG258Q, I fell in love with that monitor, I do not know why, but it happened, 240 fps .. Well I have it, the problem is that everything works fine, I did everything you do when you build your computers, also install the latest versions of the drivers, I did all that, the FPS counter that comes included in the monitor says 240fps, in the control panel of Nvidia in the resolution says it is at 1920x1080 (native) Refresh Rate of 240Hz, but the games do not go to 240fps, such as "Forza Motorsport 7," using the FPS counters "MSI Afterburner and RTSS," adding the FPS counter that the game includes, the game does not look at the refresh rate capability, when I put it to go to 250 Hz in the Nvidia panel control, the FPS counters mark only 60fps, when I switch to go to 60hz in the Nvidia panel control, the FPS counters dial only 15fps !!! is crazy man, I also play a game in chrome, a game that maybe many believe is silly but no, not for me, ok there is a proof that there is something wrong with my pc, I see players with graphics like the gtx 1070, the game is going to 144htz, the game does not require much because it is a 2D game but it looks very good, to them the fps are stable, no more no less, the internet they have is slow, my internet is 120mgps ...I tried using a website to test the fps, called "TestUFO," it says I have 240fps but when I play the fps they go from 240-60 fps, it's crazy! I do not know what the problem is, the games are the same as trying to play on a low-end laptop ... spend a lot of money for this and I'm not comfortable, so I ask for your help, in case someone is already passing through same as me ... I hope for some people this is easy to do, but not for someone new, someone to tell me that I'm doing wrong, that I should replace, or just something is stupidly wrong hahaha :cbbbb.PNG.65757e4baaa56348b2def7c261c88ce1.PNGbbbbbb.PNG.0e5c6516f43c37556a5b831beae28942.PNGbbbbbbbbbbbbbbbb.PNG.18721f50a2a1f99d02e1a16dc996705a.PNGbbbbbbbbbbbbbbbbbbbb.PNG.cb07c94ceda560421df701a639304da5.PNGbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb.PNG.a3bdc7be9416cc580a8118cd636505ba.PNGbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb.PNG.22d28bd488b95a3d734f68c765ccd470.PNGbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb.PNG.83b9937ea264a68bb8fda4d1d7a0a57a.PNGvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv.thumb.PNG.86ac949c0c2363c5d2ebb1c2301c8dbd.PNGbbb_LI.jpg.7410569040eb316e20fb73a16697b7d2.jpg
https://linustechtips.com/topic/876802-problems-with-computers/
vsync and frame limits are all off in the game settings?
https://linustechtips.com/topic/876802-problems-with-computers/#findComment-10854066
2 minutes ago, wualter reyes said:
How do the configurations need to be?
In the GAME settings not your GPU settings.
https://linustechtips.com/topic/876802-problems-with-computers/#findComment-10854076
