I want to put this https://www.amazon.com/gp/product/B01N57LAE0/ref=as_li_tl?ie=UTF8&tag=j012c-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B01N57LAE0&linkId=68b08e9bcdb943fcb10c319a5b43cd75
into a Corsair 100r, I put all my parts through pc part picker, does pc part picker consider clearance issues? Will this cooler fit?
https://linustechtips.com/topic/876793-will-it-fit/
Should be alright here is an example with the H80i in the rear.
Image result for Corsair 100r
https://linustechtips.com/topic/876793-will-it-fit/#findComment-10854014
