Hi, I'm building my first ever pc. I've spent some time doing reaserch but I'm still not sure if I did everything right and If that pc build is the best option for my budget, wchich is under £700. I am asking you to check it and give me some advice for cheap improvments or better alternatives.
•Gtx 1050ti
•Amd ryzen 5 1400
•Msi B350 Gaming pro
•Kingston HyperX 2133mghz (2x4)
•WD blue 1tb
•Kingston UV400 ssd 120gb
•Corsair VS450
•AeroCool 300
Thanks a lot.
https://linustechtips.com/topic/876717-need-help-with-my-build-please/
get a CX450/M or be quiet pure power 10 instead of the VS450.
A bit over budget.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (£166.79 @ Aria PC)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  (£63.98 @ Amazon UK)
Memory: G.Skill - Ripjaws 4 Series 8GB (2 x 4GB) DDR4-2800 Memory  (£73.39 @ Amazon UK)
Storage: Crucial - MX300 275GB 2.5" Solid State Drive  (£69.99 @ Amazon UK)
Storage: *Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£37.79 @ Aria PC)
Video Card: Sapphire - Radeon RX 580 4GB PULSE Video Card  (£232.48 @ More Computers)
Case: BitFenix - Nova ATX Mid Tower Case  (£21.95 @ Overclockers.co.uk)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£47.97 @ Box Limited)
Total: £714.34
Generated by PCPartPicker 2017-12-24 00:52 GMT+0000
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  (£73.25 @ More Computers)
Memory: Crucial - Sport LT 8GB (1 x 8GB) DDR4-2400 Memory  (£77.20 @ Aria PC)
Storage: Kingston - A400 120GB 2.5" Solid State Drive  (£41.95 @ Aria PC)
Storage: Toshiba - Product Series:DT01ACA 1TB 3.5" 7200RPM Internal Hard Drive  (£35.95 @ Amazon UK)
Video Card: Gigabyte - Radeon RX 580 4GB Gaming 4G Video Card  (£227.99 @ Aria PC)
Other: Game Max GMX-CENTAURI-BLK Centauri Gaming Case with 1 x 15 Blue LED Rear Fan and Side Window - Black/Grey  (£29.99 @ Scan.co.uk)
Total: £701.09
Generated by PCPartPicker 2017-12-24 00:58 GMT+0000
•Gtx 1050ti
•Amd ryzen 5 1400
•WD blue 1tb
•Corsair VS450
•AeroCool 300
Thanks a lot.
A 1060 3GB is a better option for 1080p gaming, if that’s what you’re doing.
1 minute ago, Jeremiasz said:
Thanks so such a quick responds ; )
Is it better to get single 8gb of ram or 2x4 ? I am leaning towards first build from seon.
Two sticks will technically perform better in some situations, but a single stick will be better for upgradability (especially since I just remembered the motherboard only had two RAM slots). The main reason was mostly the frequency, which will impact the performance more.
