Graphics Related Issues
Just now, toastythomas said:I haven't touched the GPU settings at all.
ok then i guess onto general troubleshooting then:
after each step, check the result. if one step fixes it then great, if you go through ALL OF THIS, even the reinstall of windows then there is hardware level damage to the CPU or mobo
run crystaldisk info and check drive health
check ALL CABLES at BOTH ENDS
reset CMOS
remove the graphics card and try on the IGPU
try the GPU in another system
if the IGPU still has problems its probably not the GPU, if the IGPU has no problems then its graphics card related and you should probably try RMA it, but you can also try:
run memtest 86, any errors mean that there is a problem with that RAM stick
try each ram stick alone in the first slot
reseat CPU
check for any scratches or damage
reinstall windows, clean
