I built a computer around 2 ish years ago now and  its been running great until today....
I went to boot my rig to play some Pubg and Overwatch, and to my surprise pressing the power button did not make my system engage in any boot sequence what so ever...
I checked all the front panel connections and everything checked out, except still no boot. The motherboard has a indication LED that it is powered so I unplugged the Power Switch header and tried to start a boot using my screwdriver to complete the circuit, and to my surprise still no boot! What could this mean for my PC ...
PLEASE HELP I DONT WANT MY BABY TO BE DEAD :(
https://linustechtips.com/topic/876427-pc-wont-boot-help/
Specs?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/876427-pc-wont-boot-help/#findComment-10850946
7 minutes ago, thrilledtear said:
i7 - 4770k
Asus Z87-a
16gb of kingston black ddr3 memory
gtx 970 Gigabyte
(booted perfectly for the two years ive had it)
psu? slight chance there's a problemo there
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/876427-pc-wont-boot-help/#findComment-10850963
Start with the very basic stuff (this stuff sounds mundane but is easy to miss)
Ensure the machine is plugged in to the wall
Make sure the wall outlet is switched on
Make sure the psu switch is on
Make sure the cable from the wall to the PSU works
Next try a cmos reset
1) Unplug the power lead from the PSU
2) Remove the battery from the motherboard
3) Wait for a few minutes
4) Replace everything and see if it boots
5) If anyone tells you to hold the power button down ignore them, it's an unnecessary myth.
Main Rig:-
Server:-
https://linustechtips.com/topic/876427-pc-wont-boot-help/#findComment-10850971
Hold down the power button.
It's not a race to the bottom.
https://linustechtips.com/topic/876427-pc-wont-boot-help/#findComment-10851017
