Hi, I want to switch from an AIO to a custom water cooling loop since my new processor runs a bit hot. I just want the best performance and I am not concerned about cost. The only issue is that I have never built a custom loop. After some digging I found that some companies sell water cooling loop kits. Would it be a good idea to start with a kit and if so which kit would be the best?
https://linustechtips.com/topic/876342-water-cooling-loop-kit/
If costs don't matter I would recommend EK's Performance series. https://www.ekwb.com/shop/kits/performance-series
It features a D5 pump which is the best pump you could have for a water cooling loop. The Extreme series has a DDC pump which is not bad either but the D5 is better as it makes less noise and is actively cooled by the liquid passing through.
BUT, these kits all use soft tubing and if you want to go with hard tubing straight away it's better to get all part separately.
Hard tubing requires other fittings than soft tubing and if you want to switch later on you would have to buy new fittings to when going with a kit.
Basically you need a:
- Pump (Preferably a D5)
- CPU block
- GPU block (optional and you should check compatibility)
- Radiator(s) (for performance I would say at least 240mm per block)
- Fans for your radiators.
- Fittings (2 per component)
- Tubing (with hardline bends take a bit of practice so get double or triple the length you actually need)
- Hardtubing tools (Like this: https://www.ekwb.com/shop/ek-hd-tube-d-i-y-kit-10and12mm)
- Pipe deburrer
- ATX Bridge plug (https://www.ekwb.com/shop/ek-atx-bridging-plug-24-pin) for filling and bleeding while everything is powered off expect PSU and pump.
I would also advice to watch some tutorials at JayzTwoCents channel on youtube. And start with planning your loop by making drawings before buying and installing your loop.
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
https://linustechtips.com/topic/876342-water-cooling-loop-kit/#findComment-10850309
What case do you have?  EK is best for kits, the EK-mlc pheonix may be good if you want something super simple (it's basically a modular aio)
Best premade kits
https://www.ekwb.com/shop/kits/extreme (Weaker pump, better rad)
https://www.ekwb.com/shop/kits/performance-series (better pump, weaker rad)
Pheonix
https://www.ekwb.com/shop/aio/ek-mlc
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/876342-water-cooling-loop-kit/#findComment-10850311
I wouldn't do a kit myself. Most kits aren't enough for a whole system but they sell kits to expand aswell.
As far as companies, some may have better performance but a few Celsius isn't gonna change my mind when they look crappy.
So I got for looks that way it can match, at least block wise. Fun to make your own setup then be left doing some kit.
https://linustechtips.com/topic/876342-water-cooling-loop-kit/#findComment-10850409
Best premade kits
Pheonix
Thanks for replying :) . I have an inwin 303 currently but I plan on switching to a full tower. I also plan on learning more about custom loops so I would prefer to have at least a basic loop to start.
https://linustechtips.com/topic/876342-water-cooling-loop-kit/#findComment-10850477
- CPU block
- Pipe deburrer
Thanks for the reply :) . I don't want to start with hard tubing because the increased difficulty. Noise does not bother me too much, would that make the DDC pump a better choice since I am looking for the best performance? Is non-conductive fluid worth it? I just checked out jay2cent's channel and that should help significantly.
https://linustechtips.com/topic/876342-water-cooling-loop-kit/#findComment-10850495
Thanks for the reply :). If I make a loop and have all the parts needed is there anything to look out for to prevent a leak?
https://linustechtips.com/topic/876342-water-cooling-loop-kit/#findComment-10850507
- CPU block
- Pipe deburrer
Would it be much more difficult if I put a block on my graphics card and is it worth the trouble?
https://linustechtips.com/topic/876342-water-cooling-loop-kit/#findComment-10850527
Straight compression fittings. Least amount of points of failure.
I would do the card too. Custom loops for a CPU only is a waste.
https://linustechtips.com/topic/876342-water-cooling-loop-kit/#findComment-10850547
4 minutes ago, Mick Naughty said:
Straight compression fittings. Least amount of points if failure.
Yeah I heard that barbs are worse.Good point. I guess a CPU and Graphics card loop is the plan :).
https://linustechtips.com/topic/876342-water-cooling-loop-kit/#findComment-10850561
The performance kit is your best bet then, nab the 360 version and you can transfer it over to a new case pretty easily.
https://linustechtips.com/topic/876342-water-cooling-loop-kit/#findComment-10850608
I used barb for both of mine as they're cheap and I would risk it. But compression ones went on sale and converted one of mine. Didn't even bother to leak test, easy hassle free and look much better.
https://linustechtips.com/topic/876342-water-cooling-loop-kit/#findComment-10850693
Is there a noticeable performance difference between the performance kit and the extreme kit?
https://linustechtips.com/topic/876342-water-cooling-loop-kit/#findComment-10850849
The extreme has a better radiator but worse pump, go for PE
https://linustechtips.com/topic/876342-water-cooling-loop-kit/#findComment-10850852
