You will still need a monitor
Location?
Desktop benching:
https://linustechtips.com/topic/876070-mini-itx-build/#findComment-10848235
Motherboard: ASRock - H110M-ITX/ac Mini ITX LGA1151 Motherboard  ($68.49 @ SuperBiiz)
Memory: Crucial - 8GB (1 x 8GB) DDR4-2400 Memory  ($84.88 @ OutletPC)
Storage: Toshiba - P300 1TB 3.5" 7200RPM Internal Hard Drive  ($39.88 @ Other World Computing)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($32.99 @ Newegg)
Total: $226.24
Generated by PCPartPicker 2017-12-22 02:02 EST-0500
https://linustechtips.com/topic/876070-mini-itx-build/#findComment-10848255
20 minutes ago, Being Delirious said:
Just worry about the computer itself and Canada @herman mcpootis
Motherboard: ASRock - H110M-ITX/ac Mini ITX LGA1151 Motherboard  ($85.50 @ Vuugo)
Memory: Crucial - Sport LT 8GB (1 x 8GB) DDR4-2400 Memory  ($99.99 @ Amazon Canada)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($54.75 @ Vuugo)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($57.99 @ PC Canada)
Total: $298.23
Generated by PCPartPicker 2017-12-22 02:24 EST-0500
https://linustechtips.com/topic/876070-mini-itx-build/#findComment-10848278
Size of graphics card?
Desktop benching:
https://linustechtips.com/topic/876070-mini-itx-build/#findComment-10848344
16 minutes ago, Being Delirious said:
I already have one I said
For example, try fit your graphics card inside this
https://pcpartpicker.com/product/7RTrxr/antec-case-vsk2000u3
Desktop benching:
https://linustechtips.com/topic/876070-mini-itx-build/#findComment-10849116
