Hi guys,
Wile flashing one of my GPU, I used the wronf file, now I can't even run my PC wile it is connected because windows wont boot. Do you ksnow any easy way to reflash it? Or can anyone can help me to flash it using a DOS boot usb drive?
Note: I run Ryzen 1500x, so no integrated GPU, I have 3 RX 580 and one that I need to reflash.
Thx for your help!
https://linustechtips.com/topic/875910-flashing-gpu-using-dos/
yeah just make a DOS boot drive... put atiflash in a folder on it and the rom/bios
then cd to the atiflash directory and run atiflash pointed to your rom file and make sure you select the right card to flash... then there you go.
there is plenty of guides on how to use atiflash with a dos bootable USB if you need more help.
like this one: https://getpimp.org/undervolting-howto/
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
https://linustechtips.com/topic/875910-flashing-gpu-using-dos/#findComment-10849579
Thx, I never used DOS befor, so it is exacly what I need. The only thing is that I can't even make a bootable USB drive using MS-DOS.... dont know why, the option does not show up in Rufus,
Any help?
Thx
https://linustechtips.com/topic/875910-flashing-gpu-using-dos/#findComment-10854000
