AIO Reliability and Recommendations
12 minutes ago, megamawman said:Hey folks,
Recently, I've been looking to update my PC to an AIO water cooler for the Threadripper 16-core I will soon get. I will mainly be using this system for 3D rendering in Max and VRay along with UE4. As a result, these long sessions of 100% CPU usage (potentially 2+ hours) has pushed me to buy a cooler to fit my needs. After doing some research, I have found that AIO liquid coolers often have pump failures after 8-12 months and 1-2 weeks of down time could kill a contract for me if I have to get a cooler RMA'd. I found this was true on the H100i (gtx and v2) and the Kraken X62 and X52 which both appear to be popular coolers. Are these reviews just people getting unlucky with faulty pumps or is this is a serious issue I should be considering?
I'd probably get a big air cooler, like a nh-d15 (if size isnt an issue) as there is less to go wrong and if the fans do fail the heatsink will still dissipate some heat.
