So my family has a pc for watching online shows and this pc is hooked up to our TV, so its like a PC but u can sit on your couch. Anyways its a old Xp machine, i build if from a week or so ago. it has like 5 programs on it, chrome, IE, Adobe flash/reader, java, and Avast. And before we used it, the HDD was wiped and i re-installed Windows and all the drivers, and yes all the parts are compatible. About 3 mins after we start it, the CPU goes from 3% to 12% then to 100% and it stays there forever until we restart. Both ram sticks are the same speed, all the drivers are up to date, and the cpu has plenty of thermal compound and lots of air movement. My dad even had some industrial thermal compound with copper and aluminum dust in it, no difference. Its a old noisy HDD that we have had problems with so i am suspecting that, but do any of you have any other ideas?
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/87562-100-cpu-help/
Specs would help.
MOBO - Asus Sabertooth 990FX R2.0   CPU - AMD Phenom II X6 1055T @ 3.5GHz - Corsair H80i   RAM - 2x Corsair Vengence 4GB DDR3 @ 1666 MHz
GPU - SAPPHIRE 100362-3L Radeon R9 290 4GB Tri-X OC  Sound - ASUS Xonar DSX  PSU - Thermaltake SMART M Series SP-850M 850W
https://linustechtips.com/topic/87562-100-cpu-help/#findComment-1187377
Heat wouldn't cause your CPU usage to go up. To much thermal paste is actually worse than not enough just so you know and I would watch out for that stuff that your dad is using. It is highly conductive and would make some nice sparks if something where to happen.
https://linustechtips.com/topic/87562-100-cpu-help/#findComment-1187379
Go to "start" then type "power options" in search, then in power options click on "Change plan settings" then click on "Change advanced power settings" then a new window will pop up then go scroll to "processor power management" and click on it then open "minimum processor state" and check if the value is at 5%. If not put it at 5% and then restart your PC and check if the problem is fixed.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/87562-100-cpu-help/#findComment-1188138
Go to your task manager then under process sort by CPU usage, there might be some sneaky software/malware using up your CPU.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/87562-100-cpu-help/#findComment-1188726
Is Avast running active background checking? That could do it. Pic from task manager will help, but sort by ram usage instead. CPU usage may vary too much even though it runs at 100%.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/87562-100-cpu-help/#findComment-1188750
can you show us your process explorer/ task manager
I figured it out, it was trying to search for updates, and when it couldn't find any, it looked harder and allocated 100% of the cpu. Turning off automatic updates fixed it. If the problem still exists then i will try your thing Leonard
https://linustechtips.com/topic/87562-100-cpu-help/#findComment-1189455
Cool.
https://linustechtips.com/topic/87562-100-cpu-help/#findComment-1193121
