does someone else fit a gtx 1060 in it or does it come out the factory with a 1060?
Desktop benching:
https://linustechtips.com/topic/875597-i-need-help/#findComment-10843805
Well, if you look at it, an i5 7400 uses something like 70w max and a 1060 uses around 120w max. While not ideal, and something I definitely wouldn't do, it would technically work. But that's not taking into account peripherals, hard drives, ram, case fans and stuff like that. You'd really be pushing it with a 260w PSU and I don't think it'd be safe. I'd 100% recommend getting a new PSU, even something like a Corsair CX450m. That 260w could be an awful brand and I have absolutely no idea why it'd be put in a build like that.
Gaming PC: i5 8600k @ 4.8GHz | 16GB T-Force Delta RGB @ 3200Mhz | Asus Prime Z370-A | Sapphire Radeon VII (Dead :( ), RX480 8GB | EVGA SuperNova 750 G2 | 120GB Sandisk SSD Plus, 120GB Kingston A400 | 4TB Seagate 7200RPM , 1TB WD Blue 7200RPM | Phanteks P400 Windows 10, MacOS Catalina
Second PC: i5 3340s @ 2.8GHz | 8GB Corsair Vengeance @ 1333MHz | EVGA 750Ti SC | Cheap £7 250GB WD HDD Windows 7
LaptopLate 2009 MacBook (Core 2 Duo, 4GB Ram, 120GB SSD, 9400m, running Mojave) , Late 2013 MacBook Pro Retina (i5, 4GB Ram, 128GB SSD)
Consoles: Xbox One, PS4 Slim, PS3 slim, Xbox 360 fat still going strong after almost 10 years, Original Xbox, PS2, PS1
Phone: Realme 6, Xiaomi Mi A2, Xiaomi Redmi Note 4x, iPhone 6s (jailbroken)
Tablet: iPad Mini 2nd Gen Retina (Jailbroken)
Headphones:  Hifiman HE4xx, Phillips Fidelio X2, Status Audio CB-1,  Fiio E10k DAC, Schiit Magni 3+, Tin T2 IEM's, Astrotec S80
Keyboards:  2x Custom 60% - 1x Gateron Yellow, 1x Box Reds
https://linustechtips.com/topic/875597-i-need-help/#findComment-10844126
3 hours ago, David.eman said:
It comes out the factory
Oh and what brand is it? If it's some large reputable company then it is fine. Probably not something you want to overclock on, but then large companies wont run risks of using a PSU that's too weak because they are the ones providing warranty and they will lose money if too many of these got sent back for repairs.
Desktop benching:
https://linustechtips.com/topic/875597-i-need-help/#findComment-10844531
4 hours ago, Brian said:
Not sure any company would sell a system with a 1060 and a 260w psu.  Do you have a link to the system builder website?
The HP prebuilts my high school used for VR had QC-HT Xeons with GTX 1060s on 280W PSUs, so it would run more than fine. Manufacturers aren't that dumb.
Considering an i5 7400 and 1060 might draw 200-210W under load, the 260W PSU is fine.
https://linustechtips.com/topic/875597-i-need-help/#findComment-10844753
