Need help on choosing a gpu on stores around me
Yana
Hello! I am wanting to get a 1060 6gb gpu from the stores locally around me, why you ask?  I do not have a credit card and my mom really just wants to order locally so that if there is something wrong with the pc part, itll be easier to return. The stores around me are bestbuy ,staples, office max etc.  This is an example of what i see in bestbuy's store https://www.bestbuy.com/site/searchpage.jsp?cp=1&searchType=search&st=1060 6gb&_dyncharset=UTF-8&id=pcat17071&type=page&sc=Global&nrp=&sp=&qp=currentprice_facet%3DPrice~%24250 - %24499.99&list=n&af=true&iht=y&usc=All Categories&ks=960&keys=keys
Just go for the lowest cost one they are mostly all the same.
I too bought my 1060 6gb from bestbuy last year.
Really? They really all just the same? And what happens if the card i buy makes a ton of noise
Yea they are basically all the exact same gpu and vram and heck some are the same pcb.
you might see a 1% difference in the in SOME aspect somewhere but yeah it doesn't really matter they are all pretty much the same.
put on some headphones and drown it out
put the computer in a different room
return it for a quieter one
don't buy one in the first place
play checkers , that's a nice quiet game. you get my point lol
go for one that isn't a blower-style card as they tend to run hot and loud. otherwise try to get one with 2 fans on it. otherwise almost every single gpu is a good choice. (asus, msi and gigabyte are some of the more commen gpu makers and those gpu's are always not a bad choice)
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
alright thank you!
any idea what PNY? The brand name for gpus
never had that one, but it's a good budget card according to other people. maybe you got a palit somewhere in store?
Nothing wrong with getting them from best buy. Same gpu regardless. Temps will be fine assuming the case isn't shit.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
