So I am currently running an asus VIII formula. And I just got a razer base station chroma as a gift. But the problem is that whenever I connect it to my PC, I cannot boot it.
It just turns on, goes through a few post codes, eventually getting stuck on 6C, before flashing to 99 then restarting.
I have tried disabling fast boot, updating chipset and USB drivers etc, I can't get it to work.
If I unplug it then plug it in AFTER windows has booted it works absolutely fine.
Is there a way to suspend starting a USB hub/controller until after the PC posts?
Video reviews: https://youtube.com/goldensound and https://www.youtube.com/c/TheHEADPHONEShow Written reviews and measurements: https://goldensound.audio
Current Main Setup: Roon -> HQPlayer -> Holo Audio May KTE DAC-> Holo Serene KTE preamp -> Benchmark AHB2 (Speakers) / Zahl HM1 (Headphones)
Most used headphones: Hifiman Susvara, Abyss 1266 Phi TC, Sennheiser HD800-S, ZMF Atrium
Speakers: Focal Sopra No3 + 2x SVS SB-16 Ultra
https://linustechtips.com/topic/875396-need-some-help-solving-a-code-99-boot-loop/
