I've got about $40 left in my budget and am willing to spend $50 at the most on an aftermarket cooler. Any suggestions for my R5 1600?
??? Wanna join ??? my free??gift card??? giveaway??? Click ⤵ the subrscribe button?? ,turn? the notifications on ??? and finally leave a nice comment ??down below⬇⬇ , now without further adue ??? lets get on?? with the video▶▶
https://linustechtips.com/topic/875324-30-50-cooler/
I've heard good things about the Noctua NH-D15(just get different fans for it) or the bequiet! Dark Rock /Shadow Rock series
https://linustechtips.com/topic/875324-30-50-cooler/#findComment-10841283
The NH-D15 is minimum $80 so rip his budget
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
https://linustechtips.com/topic/875324-30-50-cooler/#findComment-10841295
You can get the Macho, or a few quite.. THICC air coolers, nothing quite as good as a D-15, but more than enough for a 1600
https://pcpartpicker.com/product/4TCrxr/thermalright-cpu-cooler-machorevb
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/875324-30-50-cooler/#findComment-10841316
Gammax 400
212 evo
Cryorigs H7
Cheapest to best.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
https://linustechtips.com/topic/875324-30-50-cooler/#findComment-10841364
Have you tried with stock yet? And if so, what is the primary reason for getting aftermarket? I would recommend saving some more and getting quality midrange cooler rather than going for budget when you already have stock cooler.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/875324-30-50-cooler/#findComment-10843302
No, My plan is to stick with the stock. But I was asking incase anyone had any ideas that I would consider when I upgrade later on.
https://linustechtips.com/topic/875324-30-50-cooler/#findComment-10843317
You can straight forget budget options. Scythe Fuma is good one, if you need performance and don't care noise that much. Beyong that, Cryorig, CM, Noctua and be Quiet midrange cooler (H5, DR3, MasterAir something and U12S/U14S) are ones to look for.
https://linustechtips.com/topic/875324-30-50-cooler/#findComment-10843332
https://www.newegg.com/Product/Product.aspx?Item=1DR-003S-00004 fits squarely into your budget and performs on par with 240mm AIOs.
 if the upgrade kit isn't included then order one from reeven.
https://linustechtips.com/topic/875324-30-50-cooler/#findComment-10845370
Scythe FUMA Rev.B or Thermalright Macho Rev.B.
The FUMA outperforms any air cooler on the market when mounted properly.
The Macho is just as good as the NH-D15 and it's more quiet.
AX1600i owner. https://docs.google.com/spreadsheets/d/1_GMev0EwK37J3zZL98zIqF-OSBuHlFEHmrc_SPuYsjs/edit?usp=sharing My WIP Power Supply Guide.
https://linustechtips.com/topic/875324-30-50-cooler/#findComment-10845672
Any reviews to back these? Or just your opinions?
https://linustechtips.com/topic/875324-30-50-cooler/#findComment-10845714
I have a Cryorig H7 and a Noctua NH-U12S.  The H7 only has 3 heat pipes and can't keep up with the Noctua.  The cooler master 612 v2 has 6 heat pipes and is $35 on Amazon right now.  If you can't fit something like that in your case then you might be able to find a MasterLiquid 240 Lite on sale.  I have been seeing them from $39-49 on sale off and on all season.  I have one and cools nicely even with stock fans.  I replaced the fans with slower more quiet Noctua's and still cools great.
https://linustechtips.com/topic/875324-30-50-cooler/#findComment-10846410
Cryorig H7 or Stock cooler.
AMD Ryzen 1700x
ASRock x370 Taichi
Corsair Vengeance RGB 16GB GDDR4 3200
EVGA GTX 1080 Ti K|NGP|N
Fractal Meshify C
Samsung Evo 960 Nvme M.2 500gb & WD Blue 1TB
Corsair TX850M Gold
Alienware AW2518H 240Hz Gsync
Audioengine A2+ & Sennheiser HD6xx /w Fiio K5 Pro
Deepcool Captain 240Pro V2
Vortex Race 3 Cherry Mx Red
Corsair Vengeance M65 PRO RGB
https://linustechtips.com/topic/875324-30-50-cooler/#findComment-10849259
Try the stock Wraith Spire first. It'll get an R5 1600 to 3.7-3.8 GHz with no thermal issues. If that doesn't work, the Cryorig H7 and Deepcool Gammaxx 400 are good, cheap options. The Cryorig H5, which I'm using with my R7 1700, is the top of your budget, but it's overkill if your case and mobo can handle it, and will run damn near silent.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/875324-30-50-cooler/#findComment-10849365
