Putting together a PC for ~1000$
Hey guys!
I just need some advice on buying parts for a new PC (budget ~1000$).
Link to PCPP.
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor
CPU Cooler: Cooler Master - Hyper T4 70.0 CFM Rifle Bearing CPU Cooler
Motherboard: MSI - B350M GAMING PRO Micro ATX AM4 Motherboard
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3200 Memory
Storage: SanDisk - X400 256GB 2.5" Solid State Drive and Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card
Case: (not included on PCPP) SilentiumPC Gladius M35 Pure Black
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Optical Drive: N/A
Operating System: Microsoft - Windows 10 Home OEM 64-bit
Tell me what you think, share suggestions. Thanks! :)
12 minutes ago, SentiWW said:
Hey guys!
Link to PCPP.
Optical Drive: N/A
Solid.  The 1070 and 1400 are a pretty good choice at 1080p and 1440 (with lower settings here).
15 minutes ago, SentiWW said:
Hey guys!
Link to PCPP.
Optical Drive: N/A
The 1070 is an outstanding GPU (in my opinion). Here is a link to what you can expect performance-wise: http://www.tomshardware.com/reviews/nvidia-geforce-gtx-1070-graphics-card-roundup,4751-2.html
MSI mobos are hit and miss I would maybe get a different brands
Ex frequent user here, still check in here occasionally. I stopped being a weeb in 2018 lol
For a reply please quote or  @Eduard the weeb me :D
Xayah Main in Lol, trying to learn Drums and guitar. Know how to film do photography, can do basic video editing
What exacly do you mean by hit and miss? I used a lot os MSI mobos in my life and all of them were pretty good. (except for the one that shorted and started a small fire ._.)
A lot of people do n't like them in general for some reason and they getted bitched on through out the forum.
Just now, ONOTech said:
I would skip over the R5 1400 and go straight to at least the 1500X, preferably the 1600. The extra cache & cores help.
Otherwise, everything else looks great.
It's on a budget limit. I would if I could... but I'm afraid I can't. :/
I tend to agree
If you scrap the T4 cooler, you can pick up a 1500X (possibly a 1600 if you stretch your budget a bit).
If you can't, it's not the end of the world either. You're not sacrificing that much performance when paired with a 1070 at 1080p. Good luck!
Scrapping the cooler? What about the temps tho!? o.O
The 1400, 1500X, and 1600 all come with the Wraith Cooler. It works pretty well, too. It keeps the CPUs cool up to around a 3.8 GHz overclock.
I though the cooler you get with those was bad (first build on Ryzen). Well, I will scrap it and see if the budget can take it.
Try to get the 1600 instead of the 1400. The extra cores will help with resale value, and it should last you significantly longer.
Drop the low end air cooler, the stock cooler is fine, even for overclocking.
That's the worst B350 motherboard by far. 3-phase garbage that will overheat (not shut down, it's too stupid to do that), if you do anything with an 8-core, or a slightly overclocked 6-core.
There are cheaper 8GB kits, get one of those. ≥2800MHz, brand doesn't matter.
You can get cheaper 250GB SSDs.
You can get cheaper HDDs.
If you can, try to get the 1070 Ti. 25% more performance.
The G2 550W is available for $55, get that PSU instead.
You can get a Windows key from Reddit or Kinguin for ~$25.
What about this? PCPP
(the WD 1TB stays)
