This is a new PC I have downloaded all the bios updates, and drivers.
My specs are:
Ryzen 5 1600
Gtx 1060 3gb
Gigabyte gaming 3 ab350
2x4 8gb corsair vengeance 3600mhz
On my system it comes up as: 2133 mHz
Where as on my bios I chose profile 1(xmp) which says I have 36000 mhz
https://linustechtips.com/topic/874686-ram-not-appearing-the-same-on-system/
Turn on XMP, Turn the frequency up to the maximum of either your motherboard or the RAM, whichever is lowest. You may also need to increase the voltage to around 1.37.
EDIT: The highest speeds that your mobo supports is 3200mhz OC'd. So set it to 3200mhz for the RAM.
Case: Lian-Li PC-011 Dynamic  CPUi7-7700k (4.8ghz) CPU Cooler: Corsair H100i V2 Case Fans: 5x ML120 RGB / 2x LL120  GPU: Aorus RTX 2080 Xtreme Motherboard: ASUS ROG STRIX Z270H RAM: 32GB Corsair Vengeance RGB Pro DDR4 (3200mhz) Storage: 2x 1TB SG Barracuda, 128gb BiWin M.2 SSD PSU: Corsair RM650x OS: Windows 10
he has xmp on
and dont look ram speeds wit hwindows, windows will laways say 2133mhz really, look ram speeds using cpu-z
half of the speed will be shown > example 1200mhz = 2400mhz ,  1600mhz = 3200mhz ( double data rate remember )
windows will always show the default speed of the kit, which is 2133mhz for ddr4
1600mhz for ddr3 ( in most xmp kits )
Just now, Valkyrie Lenneth said:
he has xmp on
On the bios it should tell you the correct speeds, mine always ran at 2133mhz untill i OC'd to 3200mhz which is now what it shows... Doubt im running at 6400mhz?? xD
hes bios screenshot is showing just fine that its at 3600mhz
the half mhz ( actual running speeds ) is shown by cpu-z and other monitoring tools ;p
Its showing 2133mhz too which i think is what he is asking...?
nah he is wondering why windows is showing 2133mhz ( the task manager ) well it always does that to xmp rams xD
he just has to download cpu-z and double the mh amount to get hes actual mhz, if cpu-z also shows 1066mhz ( aka 2133 ) then hes xmp profile isnt applying
Hmm still weird, i just checked mine and windows says 3200mhz, i understand what you mean now though, just kinda strange.
my windows says 1600mhz on a 2133mhz cas 9-9-11-24-1t timings set
windwos is just the worst thing to monitor with, get cpu-z/gpu-z xD and hardware monitor for monitoring stuff
Yeah i do already, hence why i had never looked at the speeds on task manager, which is what confused me xD
