I just overclocked my 4770k and it seems stable at 1.35v @ 4.5ghz. Only problem is when im stress testing (using prime 95), in the first 10 mins when everything was heating up 2 cores got up to 96 and 93 for a few mins. After, they went back down and all cores stayed at around 70-80c. Is this safe? i'm fine with up to 85c but if it's at 90+ just for a few seconds is that something to worry about? I know the stress testing might not be real world tests so I doubt it would reach that in games. Thanks!
https://linustechtips.com/topic/874548-4770k-temps/
1.35v is a high voltage for that OC. I got 100mv less at that same clock. What mobo are you running?
5800X3D / ASUS X570 Dark Hero / 64GB 3600mhz / EVGA RTX 3090ti FTW3 Ultra / Dell S3422DWG / Razer Deathstalker v2 / Razer Basilisk v3 Pro / Sennheiser HD 600
2021 Razer Blade 14 3070 / iPhone 15 Pro Max
https://linustechtips.com/topic/874548-4770k-temps/#findComment-10833701
4 minutes ago, JoshuaA9088 said:
For a 212 evo 90+ seems really high. Are you sure mounting and thermal compound are adequate?
The 212 evo has a TDP of 180 watts and the stock 4770k is 84 watt TDP. So even at 4.5ghz it seems unlikely that the cooler is the bottleneck.
https://linustechtips.com/topic/874548-4770k-temps/#findComment-10833704
Yeah i'm sure. Before overclocking it was reaching maybe like 50-65 under full load. I'll put back the voltage slightly tomorrow and see what happens but like I said it only stays there for around a min or so and then goes back to 70-80 so i'm not sure.
Using Asus z87-c mb. Min stable I was able to get was 1.2v at 4.2 which stayed around 70c.
https://linustechtips.com/topic/874548-4770k-temps/#findComment-10833708
Might just need to tune your voltages. Haswell isn't just set vcore and go until you bluescreen. Its much more involved.
http://www.overclock.net/t/1401976/the-gigabyte-z87-haswell-overclocking-oc-guide
That thread helped a ton, even if its for gigabyte boards it explains Haswell OCing well.
https://linustechtips.com/topic/874548-4770k-temps/#findComment-10833727
Just now, JoshuaA9088 said:
Check and make sure you have no automatic voltage settings enabled. That temperature change from stock is rather drastic.
There's a lot of auto ones, i'll take a look at cache ones too.
Interesting read :P i'll have a look at the other settings tomorrow.
Just on a quick side note, i put the voltage down to 1.31 and it seems stable. Under 90 on aida, haven't tried prime95.
Thanks for the help :P
https://linustechtips.com/topic/874548-4770k-temps/#findComment-10833836
