First build help needed !
Go to solution Solved by seon123,
That link doesn't work, use the permalink, or copy from the [bb] thing
I have a budget around 1500-2000€ and I live in France
The aim of this pc is to play games like LoL/OverWatch and triple-A games like Assasin creed unity all in Ultra on an ultra-wide monitor 1980-1080 at 60 fps ( I'm also looking to buy a new ultra-wide monitor with a higher resolution) and for some occasional photoshop and file regular backups of Other tech equipment.
I'm upgrading because my current pc can't play Triple-A games and because I have the possibility of upgrading.
Here is my list of parts I think the Nivida 1080Ti is a bit overkill and I'm not too sure about the other parts even doe I want to stay Intel-Nvidia
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  (€284.93 @ Amazon France)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  (€117.64 @ Amazon France)
Motherboard: Asus - Prime Z370-A ATX LGA1151 Motherboard  (€179.40 @ Amazon France)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  (€140.10 @ Amazon France)
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive  (€267.95 @ LDLC)
Video Card: EVGA - GeForce GTX 1080 8GB Superclocked Gaming ACX 3.0 Video Card  (€599.95 @ LDLC)
Case: NZXT - S340 (Black) ATX Mid Tower Case  (€76.27 @ Amazon France)
Power Supply: SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply  (€71.68 @ Amazon France)
Case Fan: Corsair - Air Series AF120 Quiet Edition 39.9 CFM  120mm Fan  (€14.95 @ Amazon France)
Total: €1767.82
Generated by PCPartPicker 2017-12-17 18:03 CET+0100
https://linustechtips.com/topic/874353-first-build-help-needed/
I have the 8600k and Asus Prime Z370-A combo. It's good for 5GHz+. I had mine at 5.1GHz but my poor Cryorig H7 could barely cope with it, which is no surprise. I would strongly advise getting a better PSU. Something like a Seasonic Prime Titanium 650w or 750w.
Gaming PC: i5 8600k @ 4.8GHz | 16GB T-Force Delta RGB @ 3200Mhz | Asus Prime Z370-A | Sapphire Radeon VII (Dead :( ), RX480 8GB | EVGA SuperNova 750 G2 | 120GB Sandisk SSD Plus, 120GB Kingston A400 | 4TB Seagate 7200RPM , 1TB WD Blue 7200RPM | Phanteks P400 Windows 10, MacOS Catalina
Second PC: i5 3340s @ 2.8GHz | 8GB Corsair Vengeance @ 1333MHz | EVGA 750Ti SC | Cheap £7 250GB WD HDD Windows 7
LaptopLate 2009 MacBook (Core 2 Duo, 4GB Ram, 120GB SSD, 9400m, running Mojave) , Late 2013 MacBook Pro Retina (i5, 4GB Ram, 128GB SSD)
Consoles: Xbox One, PS4 Slim, PS3 slim, Xbox 360 fat still going strong after almost 10 years, Original Xbox, PS2, PS1
Phone: Realme 6, Xiaomi Mi A2, Xiaomi Redmi Note 4x, iPhone 6s (jailbroken)
Tablet: iPad Mini 2nd Gen Retina (Jailbroken)
Headphones:  Hifiman HE4xx, Phillips Fidelio X2, Status Audio CB-1,  Fiio E10k DAC, Schiit Magni 3+, Tin T2 IEM's, Astrotec S80
Keyboards:  2x Custom 60% - 1x Gateron Yellow, 1x Box Reds
https://linustechtips.com/topic/874353-first-build-help-needed/#findComment-10832097
Just now, VenomCow said:
Why would I need more Wats on my power supply if it consumes 474W ?
The 550 watts is only at top efficiency, which you are not going to be at all the time, and if you want to overclock a little (since you have a k-processor, an aio and a z370 mobo) some more headroom would be adviced
https://linustechtips.com/topic/874353-first-build-help-needed/#findComment-10832115
It's good to have some headroom with a power supply, because if you add another component or start overclocking, you're going to be pretty close to the limit. Additionally, power supplies have greatest efficiency at around 50% load.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/874353-first-build-help-needed/#findComment-10832117
If you pick a 1080 instead of a 1080Ti, and you go with two rather than four fans, you can save a fortune.
Also I would strongly advise against using quad channel on a 4 slot motherboard, as you might need to upgrade your memory at some point.
https://fr.pcpartpicker.com/list/93rpZ8
De rien! ;)
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
https://linustechtips.com/topic/874353-first-build-help-needed/#findComment-10832128
Realistically, he's going to be looking at under 400W load. Under 450W with an overclocked 1080 Ti and overclocked CPU.
The difference in efficiency between 50% load and 100% load is 3%. That's not worth it for the additional cost, even assuming 100% system load several hours every day.
There's a reason why the B1 700W, VS650, CX850 etc make no sense.
https://linustechtips.com/topic/874353-first-build-help-needed/#findComment-10832493
