So I recently ordered a cyberpowerpc gamer xtreme i7 gtx 1060 3gb, and my computer is using integrated graphics and my nvidia control panel will not open. I do not know how to fix this, the driver shows up on geforce expericnce and in my device manager. When I disable intel graphics it uses microsoft basic display drivers.
https://linustechtips.com/topic/874204-i-need-help-please/
Hi,
Go into "Device Manager" and uninstall the graphics drivers for your Nvidia card, then make sure you are using output from the card itself.
Lastly, in the BIOS (Or you younger kids UEFI) disable integrated graphics. Then proceed to do another clean install of graphics drivers from the Nvidia website.
Should this issue arise still, you may have a corrupt windows install.
Cheers,
RorzNZ, Apple Expert.
https://linustechtips.com/topic/874204-i-need-help-please/#findComment-10831045
14 minutes ago, OminousAlien said:
I didn't uninstall the previous drivers, but I went and downloaded the newest driver for my gpu. I also did a custom installation and used a clean install of the driver
It's best to uninstall the previous driver completely before you even take the old GPU out of the build, that'll insure that the old driver with not interfere with the new one (there are programs available for that)
4 minutes ago, Alexsolo said:
Plug your monitor into the GPU output and not the motherboard output.
Do this too.
Please quote us so that we can reply to you.
https://linustechtips.com/topic/874204-i-need-help-please/#findComment-10831047
1 hour ago, OminousAlien said:
I fucking love you alexsolo, I might have a form of autism.
LOL, put this one in the books boys. Don't worry, i've plugged both ends of my dvi-hdmi cable, and wondered why my monitor wouldn't work.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/874204-i-need-help-please/#findComment-10831151
