i am now build new pc ! all the time when i am open it ! in the beginning the system told me there is problem in the cpu cooler or cpu cooler header and it told me to use F1 to change i did and try many times ! i do not know what should i do ! my cpu cooler is h100i v2 and my cpu is 8700k i7 and motherboard is asus rog x hero z370 !
https://linustechtips.com/topic/874203-help/
I think you need to use some punctuation, sir.
Plug the CPU fan connection on your H100i into the CPU_FAN1 connection on your motherboard. If there's a separate plug for the pump then plug the pump connection into the "AIO_PUMP" header on the board.
https://linustechtips.com/topic/874203-help/#findComment-10831014
i am beginner ! i will try it now
https://linustechtips.com/topic/874203-help/#findComment-10834988
