Display Port MTS Hub
kevincloon
Trying to figure out if I could run 2 1080p 60hz and one 1440p 165hz Off one display port with an MTS Hub.
I have a gtx1080 so I am currently fine without one.
My purpose is that I move my desktop between my living room and my office for VR so I'm trying to minimize the number of cables I need to unplug and replug in..
6 minutes ago, Crunchy Dragon said:
That will probably work
Alright, I'm curious if there is anything special I need, or if normal stuff works.
Like do I need a DP 1.4 Cable due to the increased bandwidth?
My current thought is:
https://www.amazon.com/EVGA-200-DP-1301-L1-Display-Port-Hub/dp/B00HK8V5KE/ref=sr_1_5?s=electronics&ie=UTF8&qid=1513376790&sr=1-5&keywords=display+port+hub
Increased bandwidth would probably help, I personally would do that just to be sure it'll work and that I'll have the bandwidth for it.
53 minutes ago, Glenwing said:
A 1440p 165 Hz monitor will consume the entire bandwidth of a DP 1.2 link, and all MST hubs available only support up to DP 1.2, so you unfortunately you will not be able to do that.
Thank you. I was trying to find somewhere someone did similar somewhere.
