http://www.microcenter.com/product/483953/Fatal1ty_Z370_Gaming_K6_LGA_1151_ATX_Intel_Motherboard
or
http://www.microcenter.com/product/484044/Z370_AORUS_Gaming_5_LGA_1151_ATX_Intel_Motherboard
The Gigabyte board is $140 after discounts, I also like the aesthetics of it a bit more.
The Asrock K6 board is $150 after discounts.
Which one is better?
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/873312-help/
a MB is an IO manifold. the only things that make it better or worse for the user is features, and VRM quality.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/873312-help/#findComment-10823204
I agree with @knightslugger.
That said, I prefer the aesthetics of Gigabyte boards to pretty much everything else on the market.
https://linustechtips.com/topic/873312-help/#findComment-10823234
Just now, RAM555789 said:
About the only difference is if you read the specs, the Gigabyte has 3 -year warranty, the ASRock has 1 year. Usually, you don't have to worry about warranty's with mobos this nice so I would just decide if the $10 is worth the look or not.
So I should choose between the two based on what i like the looks of better?
https://linustechtips.com/topic/873312-help/#findComment-10823355
that and features you want or need and/or VRM quality. if you plan to overclock, i'd put emphasis on VRM quality.
System specs:
https://linustechtips.com/topic/873312-help/#findComment-10823535
