It'll work, but I don't think that case is really that compact. It looks like it's approaching mATX territory.
But if you're coming from a midATX or full ATX, then it's definitely much smaller :P
https://linustechtips.com/topic/872838-mini-itx-build/#findComment-10818699
Well, with ~34l in volume it's far (!) away from small. You should have a look at different cases. Thet Entoo Evolv ITX is indeed more like an µATX case – and even for µATX there are smaller cases.
Use the quote function when answering! Mark people directly if you want an answer from them!
https://linustechtips.com/topic/872838-mini-itx-build/#findComment-10818714
18 minutes ago, BerserkyTurkey said:
What resolution/refresh rate are you going to be gaming at?
The i7 8700 > 8600K IMO, it's not much more money. Or an R5 1600...
The Core 500 is likely the case to get, it's more compact and supports 240mm AIOs
https://linustechtips.com/topic/872838-mini-itx-build/#findComment-10818717
Some better and smaller cases that are actually SFF:
And then there are USFF cases with less than 10l in volume like:
  • Dan Cases A4-SFX
  • NFC Skyreach 4 Mini
  • Zaber Sentry
  • Lazer3D LZ7
  • Louque Ghost S1
And then there's this µATX case: Kimera Industries Cerberus (~18l)
If more than 30l are fine with you just go with a small µATX case, save some money on more expensive ITX components, get a full size GPU and more expansion options.
https://linustechtips.com/topic/872838-mini-itx-build/#findComment-10818868
