Aura compatible LED strips and pressure fans
Solved by ricksteendam1,
2 minutes ago, ReyazJunior said:In my new pc I will be cooling my GTX 1080 Ti and an i7-8700K with an EK-MLC kit with 360 rad. I will be doing so in the Corsair Carbide Series 400C case. I need good high pressure type RGB fans for cooling the VRM and RAM and keep them cool. Because I have an ASUS ROG Maximus X Hero. A very good VRM. Should I replace the fans on the EK-MLC Core 360 Radiator Module? Or should I keep the included EK-Vardar fans for efficient cooling? And add RGB fans only for the VRM and RAM?
So which LED strips and RGB fans do you recommend? They should be ASUS Aura compatible!
https://www.newegg.com/Product/Product.aspx?Item=9SIAADY6J00966
and led strips don't matter as much
