Will My TA970 Motherboard be compatible with the AMD FX-8350 Black Edition Vishera 8-Core 4.0 GHz because im going to upgrade it and on pcpartpicker i was going to see if they would all be compatible but it said + Some AMD 970 chipset motherboards may need a BIOS update prior to using Vishera CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions. Link to list: https://pcpartpicker.com/list/GK9VsJ . So i was just wondering because i thought one day i wanna do some vr  and upgrade my pc i hope this is not going to be a issue
https://linustechtips.com/topic/871683-i-need-help/
- Moved to CPU's, Motherboards, and Memory -
 CHRISTIAN MEMBER
https://linustechtips.com/topic/871683-i-need-help/#findComment-10807423
Assume that motherboard is a Biostar one? If so, it looks like it is on the CPU supported list. Make sure you are on the latest BIOS/Agesa etc. to ensure it is properly supported before you install the new CPU, however, it may also be supported on an earlier BIOS revision, anyway.
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=623#cpusupport
https://linustechtips.com/topic/871683-i-need-help/#findComment-10809847
15 hours ago, DaRkSiDeR1080 said:
plzzz im just wondering if it will still work just say yes or no plzz
@IntMD, Pretty much summed it up for yay above, For the Moderator he was just moving the post into it's relevant area. So Don't mind him just doing his job :D. But regarding your question IntMD has summed it up nicely.
Some people prefer a challenge, I just band my head against a wall until my method works...
https://linustechtips.com/topic/871683-i-need-help/#findComment-10809854
