I got a ryzen 1700, a msi x370 gaming plus mobo, and 16gb 2x8 3000mhz corsair vengeace lpx ram
Got ram stable with xmp profile 2, 2933mhz, 15-17-17-35 cas, 1.35v Vcore, 1.2v SOC, and 1.4v Dram
I have before got 3.9 ghz stable, at 1.4v vcore, but I cant replicate no matter what I do. when I turn it on, it just boot loops, and I cant get into bios
Is there any setting I am missing that could help me get this OC stable?
thanks for any help
btw CPU cooler is wraith spire, but I'm not hitting any thermal limits
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
https://linustechtips.com/topic/871620-ryzen-1700-overclocking-help/
1 minute ago, Ryujin2003 said:
I found it easier to OC the CPU prior to meeting with RAM. You may want to look at LLC. I have similar setup, and LLC at 3 made a big difference.
but can a stable cpu oc crash the overclock? ill try with the llc on soon
Just tried mode 3, still bootloops
If the OC were stable it wouldn't crash. Something is causing issues. Reset BIOS by clearing CMOS and see it's you can get it to boot.
4 hours ago, Ryujin2003 said:
I'd the OC were stable it wouldn't crash. Something is causing issues. Reset BIOS by clearing CMOS and see it's you can get it to boot.
I have to clear cmos everytime i have a bad oc, it wont go into bios if the OC is bad
I just tried llc mode 3 without ram OC, it stays on, but doesnt post.
4 hours ago, dave_k said:
You need 5/6/7
MSI has preprogrammed 7 levels from which 4 are pointless.
Ok trying this
@Ryujin2003Now clear cmos does nothing, wont post to bios regardless. Even took out battery and still wont boot
Edit: cmos cleared when unplugged
3 minutes ago, Ryujin2003 said:
Stop what's the current status?
PC posts with ram oc.
Just now, Ryujin2003 said:
But not without RAM OC?
CPU is stock?
It post with and without ram oc with cpu at stock
CPU is stock?
got it to work, had to compromise for 3.8ghz
2933mhz ram,
vcore 1.375
dram 1.4
xmp profile 2 (3000mhz, 15-17-17-35)
vddp 1.2
llc auto
soc auto
thanks for the help
