https://ca.pcpartpicker.com/list/fJVxyf
This will be my first PC build but I am happy with everything I have chosen, except in PCPartPicker any CPU cooler I have chosen, it tells me there is an incompatibility with it. I am not sure why so I'm just coming here to ask if anyone knows the solution!
https://linustechtips.com/topic/871483-cpu-cooler-help/
older D15s might not have the mounting kit included for am4, just use the stock cooler for now if that happens and order the mounts from noctua's website if that happens, although i doubt it won't have the mounts.
https://linustechtips.com/topic/871483-cpu-cooler-help/#findComment-10805678
26 minutes ago, wONKEyeYEs said:
he doesn't have to get that unit, the normal D15 should already have it and all other mounting kits while you'd be stuck with just am4 on that model.
https://linustechtips.com/topic/871483-cpu-cooler-help/#findComment-10805845
