I am building my first ever PC and I have a parts list picked out. My Budget is £1.55K GBP and I am going for a 1080 and a i5 6600k but I am having a few problems finding ram that will fit. At the moment I just want an 1x8 GB kit and will be upgrading after Christmas when I will have more money. I anyone is willing to help me find ram that will fit with the cooller and/or compatibility check the parts I have pick then I would be extremely grateful. Also any tips or suggestions on the parts I have picked would be greatly appreciated.
Part list:
https://uk.pcpartpicker.com/list/Zk9Mqk
https://linustechtips.com/topic/871134-first-pc-build/
why not ryzen 1600 same performance with 7600 k in games.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (£175.19 @ Aria PC)
CPU Cooler: ARCTIC - Freezer 13 CO 4.0 CFM Ball Bearing CPU Cooler  (£24.24 @ Novatech)
Motherboard: ASRock - AB350 Gaming-ITX/ac Mini ITX AM4 Motherboard  (£112.70 @ More Computers)
Memory: Crucial - Ballistix Sport LT 8GB (1 x 8GB) DDR4-2666 Memory  (£78.29 @ CCL Computers)
Storage: Samsung - SM961 256GB M.2-2280 Solid State Drive  (£120.67 @ Scan.co.uk)
Storage: Seagate - Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  (£81.39 @ Eclipse Computers)
Video Card: Asus - GeForce GTX 1080 8GB STRIX Video Card  (£548.99 @ Ebuyer)
Case: Phanteks - Enthoo EVOLV ITX Mini ITX Tower Case  (£63.18 @ More Computers)
Power Supply: EVGA - SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£89.79 @ Alza)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  (£99.99 @ Amazon UK)
Case Fan: Noctua - NF-A14 PWM chromax.black.swap 82.5 CFM  140mm Fan  (£22.99 @ Overclockers.co.uk)
Other: Phanteks PWM FAN HUB (£15.32)
Total: £1478.72
Generated by PCPartPicker 2017-12-09 16:17 GMT+0000
I scaled down the 500gb 850 evo ssd to 256gb 960 nvme, you'll get x5 the speed.
skip sata drive if you can, this is 2017, move on to M2 nvme drive. 500mbps vs 3000mbps.
For secondary drive, i scaled up 1tb hdd to 3tb hdd. total you get 3.256 gb.
plus you get 8gb memory included.
https://linustechtips.com/topic/871134-first-pc-build/#findComment-10803233
