I like the Corsair Vengeance C70. Thats a nice case.
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/87061-atx-case-for-under-100/#findComment-1181114
Fractal Design Define R4 | MSI x79a-GD45 | 3960X @ 4.6Ghz | Lots of EK Blocks | EVGA GTX780Ti 3GB | Corsair Dominator Platinum 16GB (4x4) DDR3 1866 | Samsung 840 Pro 512GB SSD | Western Digital Red 2TB x4 (Raid 10) | Corsair AX760 | Windows 7 Professional 64-bit
https://linustechtips.com/topic/87061-atx-case-for-under-100/#findComment-1181145
k thanks everyone ill take a look at them 1 by 1. and report later
thanks everyone
Buy it from somewhere else, or stick it on your motherboard box.
if that were possible i wouldve originally ordered it from somwhere where it wasnt sold out
https://linustechtips.com/topic/87061-atx-case-for-under-100/#findComment-1181184
What features are important?
silence would be optimal. just dont want anything thats known to be noisey really xD. obviously if install is easy than that too.
gotta support my be quiet shadow rock 2(got it for $25 on black friday)
Then stick it on the box and wait.
ok well that doesnt work for me for a few reasons.
1 my room is a dust trap
2 next week im going to my parents house for the holidays and would like to bring my computer
3 that sets me back to using my computer in the first couple of weeks of january since real life has an effect in my life
so as helpful as u have been its just not an option
https://linustechtips.com/topic/87061-atx-case-for-under-100/#findComment-1181216
Should have asked before, what size motherboard?
https://linustechtips.com/topic/87061-atx-case-for-under-100/#findComment-1181243
Well if you want a case similar to the R4, there's always the NZXT H2 or Antec Sonatas.
Go forth and maximize profits.
https://linustechtips.com/topic/87061-atx-case-for-under-100/#findComment-1181272
hey guys my R4 is extremely back ordered so i need a replacemnt case from NCIX.com (Canada)
all help is welcomed
Fractal Design Arc Midi R2 is a great case
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
https://linustechtips.com/topic/87061-atx-case-for-under-100/#findComment-1181336
those are all cheaply built cases. Better off with an antec 300
The HAF is a solid series, I have gone one myself.  Not ritzy and a lot of the details are plastic, but the frames are all solid metal and they have great airflow.
https://linustechtips.com/topic/87061-atx-case-for-under-100/#findComment-1181360
