64 or 128 buffer. does it matter with optane memory?
will the difference between a 64 and a 128 buffer hardisk matter if you use a m2 optane to boost it?
i spent $3500(23,000dkr.) on building my pc and i only play csgo on low settings..
:Specs:
CPU: Intel Core i7-6700  CPU: Cooler: H100i v2  GPU: Gigabyte GTX 1080 G1 Gaming  RAM: Corsair Dominator 3000mhz 16GB  SSD: Kingston 960 GB  Motherboard: ASUS ROG Maximus viii Formula  PSU: Corsair RM 750x 80+ Gold  CASE: Coolermaster H500P
The performance boost would be if you pair it with a HDD, and then the size of the optane drive would be the amount of data that gains the "speed up".
If you already run a good SSD, you can leave the optane drives where they are... in the store.
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
so i should just go for the 64 mb and forget the optane?
:Specs:
if your machine is the one from your signature, forget optane
Main System:
it is. ill just get the 2tb barracuda
:Specs:
