I've got medal of honour airborne on no disk, but no optical drive. What i did, thanks to another person on this forum, was get the files from the disk onto a usb using my laptow with opt drive then go from the usb to my PC. Then i used imgburn to turn the files into an iso file and mounted it. When i have the iso mounted and try to play the game, i'm told that it's the wrong disk and that i need to insert the original disk. what do i do?
Rx580 Red Devil
Msi b40 tomahawk
Ryzen 5 2600
NZXT H500
Arctic Freezer 33
EVGA supernova 650 watts 80+ gold
3x WD caviar blue 1tb HDD
1x Corsair SSD
https://linustechtips.com/topic/869976-help-with-mounted-iso-file/
you have to get the iso file from the disk
use deamon tools to do this
disc to iso
7 minutes ago, HK - 47 said:
ive got the iso from exactly the same files as on the disk
You got files. Not copy of disc. There's obviously some hidden file etc. missing. Or even DRM which links key and disc together. Meaning that you need .ISO of your disc. Or you can try with .ISO of someone else's disc.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
disc to iso
can you link demon tools please, so i don't get a dodgy download
Rx580 Red Devil
Msi b40 tomahawk
Ryzen 5 2600
NZXT H500
Arctic Freezer 33
1x Corsair SSD
Usually software's own homepage works https://www.daemon-tools.cc/downloads
new problem, got the iso file, tried to put it on my usb (15 gig) and it said that there wasn't enough space (the iso is 7.41 gig)
Rx580 Red Devil
Msi b40 tomahawk
Ryzen 5 2600
NZXT H500
Arctic Freezer 33
1x Corsair SSD
5 minutes ago, Ethocreeper said:
free up some space on your usb
thats the thing, its empty
Rx580 Red Devil
Msi b40 tomahawk
Ryzen 5 2600
NZXT H500
Arctic Freezer 33
1x Corsair SSD
35 minutes ago, Ethocreeper said:
screenshot
so the saga continues, now with the ISO mounted, i boot the game and get the message "conflict with emulation software". AGGHHHHHHH
Rx580 Red Devil
Msi b40 tomahawk
Ryzen 5 2600
NZXT H500
Arctic Freezer 33
1x Corsair SSD
Just now, Ethocreeper said:
right click and format  then select ntfs from the dropdown
this is after all that, the ISO is on my PC and mounted but launching the game from the launcher brings up this
ignore the second screen btw, its my other monitor
Rx580 Red Devil
Msi b40 tomahawk
Ryzen 5 2600
NZXT H500
Arctic Freezer 33
1x Corsair SSD
https://answers.ea.com/t5/Other-The-Sims-Games/The-Sims-2-quot-Conflict-with-Emulation-Software-detected-quot/td-p/13098
Quote
SecuROM is detecting some type of "emulation software" on your PC. That could be something as simple as CD/DVD burning software such as Nero. If you don't have any drive emulation software on the PC, then burning software is usually the cause.
Quote
I suggest you to uninstall any burning software like Nero and drive emulation software like Alcohol 120% or Daemon Tools,
you dont need any other software to mount the iso so install any other shit
2 minutes ago, Ethocreeper said:
btw sorry for the late reply i am experiencing issues with my internet -_-
btww i have 4 monitors :P
i may have just spammed ok during an install for daemon and IMGburn. do you know where the files would have been saved by default?
Rx580 Red Devil
Msi b40 tomahawk
Ryzen 5 2600
NZXT H500
Arctic Freezer 33
1x Corsair SSD
nvr mind, got it
Rx580 Red Devil
Msi b40 tomahawk
Ryzen 5 2600
NZXT H500
Arctic Freezer 33
1x Corsair SSD
1 minute ago, Ethocreeper said:
just search unistall in windows search then select the software and press unistall
yeah, got it. But still getting the error.
Rx580 Red Devil
Msi b40 tomahawk
Ryzen 5 2600
NZXT H500
Arctic Freezer 33
1x Corsair SSD
