Hey there guys!
I am planning to get a PC in the end of the year and i came with a list (Used PC for Sale Specifications)
CPU: Intel Core i7 4770K
Code Name: Haswell
Clock Freq: 3500 MHz standard
Cores: 4 (8 threads)
Package: Socket 1150 LGA
Motherboard: Gigabyte H97M-D3H
North Bridge: Intel Haswell
Total Memory: 8192 MB
Memory 1: Team Group 4096 MB DDR3 1600 MHz 12800MB/s
Memory 2: Team Group 4096 MB DDR3 1600 MHz 12800MB/s
GPU 1: Intel HD Graphics 4600
GPU 2: NVIDIA GeForce GTX 760 2048 MB 1020 MHz by MSI TwinFrozr
OS: Windows 10 Pro 64-bit
Hard Drive 1: Samsung SSD 750 EVO 120 GB
DVD Writer: Samsung Super Writemaster
PSU: Cooler Master Silent Pro 600W
Casing: Norco Stainless Steel Rackmount 19" Industrial Grade
Total = $630.33
I can Upgrade some parts (if necessary) to
1. Sapphire RX 480 8GB Nitro+ = $259
2. MSI Z97 Gaming 3 = $121
what do you think guys? and as the rules of New Builds and Planning section i will give you 5 points about me and the PC
1. Location & Budget
I am in Indonesia, where parts are so expensive (PC parts of course) because the taxes is way high like $140 in Graphics Card section (GTX 1070 can be as expensive as 1080 here)
For Budget, i wouldn't get myself over the $1000 Line
2. Aim
I am looking forward to play at 1080p in Refresh rates above 60FPS. The heaviest game i will probably play is Tom Clancy's Ghost Recon
3. Monitors
I already have a TV that has 4 HDMI Input, for the specified name is a Samsung Curved 40" FHD TV. i guess i am looking forward to play privately by buying the LG 43UD79
4. Peripherals
I just found a $59 Corsair Void Pro, so i might go for that. Also the mouse and keyboard i have isn't gaming specified
5. Why am I upgrading?
I have a LGA 775 System right now that still performs good actually (Playing in 720p at Need for Speed Most Wanted 2005). and i want to have a significantly better PC than the old one
Ask me if you want the specs of it, but spoiler alert i am using Pixelview GF9400GT
Thank you guys!
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/868314-goin-for-haswell/
I would get a better GPU for 1080p at high refresh. A GTX 1060, RX 580, RX 480, GTX 970 or equivalent would be my recommendations for 144HZ with low/medium/high settings with some dips. A GTX 1070, Vega 56, GTX 980, for a no compromises experience at 144HZ and for low/medium/high 180-240HZ.
ORANGE SCREEN WINDOWS 10 VALUE OVER TIME - PC VS MAC
i5 7600k @ 5.0 GHz xD
Corsair H60 with Noctua NF-F12 iPPC-3000 PWM
MSI Z270-A Pro Motherboard
EVGA 1050 Ti SC
16 GB Corsair DDR4 @ 2400 MHz
500 GB Sandisk 950 PRO - Windows 10, Elementary OS, Zorin OS
500 GB Sandisk 850 PRO
1 TB WD Blue
Corsair CX750
1 x Corsair AF120 Quiet Red Led
Rosewell Tyrfing Case
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
24 GB DDR3 @ 1600 MHz
250 GB SanDisk 850 EVO - Elementary OS, Windows 10, Debian
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
8 GB DDR3 @ 1333 MHz
240 GB SanDisk - Windows 10, Linux Mint
https://linustechtips.com/topic/868314-goin-for-haswell/#findComment-10776049
I suggest a 4790k over the 4770k . The 4790k will run cooler and has a higher base clock. Also not all H97 boards can overclock so Going z97 is a better bet
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
https://linustechtips.com/topic/868314-goin-for-haswell/#findComment-10776052
i just said this in the post
My head on 2019 :
https://linustechtips.com/topic/868314-goin-for-haswell/#findComment-10776068
ok i will try to find that chip, and try to find bigger DDR3 RAM
My head on 2019 :
https://linustechtips.com/topic/868314-goin-for-haswell/#findComment-10776075
Just now, Damascus said:
I would totally get it + that mobo/gpu upgrade.  Maybe a psu upgrade as well, sell the stuff you replace to lessen the costs
i can get a $115 EVGA G750 GQ, well i can't find PSU that is bronze at less than $80
My head on 2019 :
https://linustechtips.com/topic/868314-goin-for-haswell/#findComment-10776089
@Ordinarily_Greater
If you will be using the H97M_D3, there is little point in getting an unlocked cpu. Either change to a Z97 motherboard, or drop to an i7-4770 or i7-4790 cpu. I would opt for the locked cpu. Preferably the i7-4790.
https://linustechtips.com/topic/868314-goin-for-haswell/#findComment-10776091
@brob
I already said that i want and would upgrade some parts, and it is inside this post
My head on 2019 :
https://linustechtips.com/topic/868314-goin-for-haswell/#findComment-10776138
though a new 1600 would be better
yeah but i can't manage it to be below $1000
My head on 2019 :
https://linustechtips.com/topic/868314-goin-for-haswell/#findComment-10776144
@brob
The word "can" suggests it is still under consideration.
The MSI z97 price, is that the cost of changing the motherboard, or the cost of the motherboard? If the former, I doubt it is worth the added cost.
https://linustechtips.com/topic/868314-goin-for-haswell/#findComment-10776146
the Z97 board's price is $121, it is used so i will try to make sure if it works
My head on 2019 :
https://linustechtips.com/topic/868314-goin-for-haswell/#findComment-10776165
