3 minutes ago, misterman said:
System Thread ERROW
The only errow was clicking on this thread :P
jokes aside you'll need to be a lot more specific than that if you want help. Start with describing exactly what the problem is, when it happened, what operating system and hardware you are using and what you have tried so far to fix the issue. And please make an effort to use punctuation and avoid bold/ALLCAPS when it's not needed.
sudo chmod -R 000 /*
https://linustechtips.com/topic/868167-help/#findComment-10774744
look now
https://linustechtips.com/topic/868167-help/#findComment-10774746
Just now, misterman said:
look now
Screenshots? Full specs?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/868167-help/#findComment-10774752
7 minutes ago, misterman said:
My PC is telling me there is a system thread error on my new pc i just build ryzen 1600x ram ddr4 16gb 1060 3gb
look now
https://linustechtips.com/topic/868167-help/#findComment-10774759
2 minutes ago, misterman said:
windows 10 ryzen 5 1600x 8gb ddr4 1060 3gb winforce
We still need what you were trying to do when this happened, your OS, what troubleshooting you've already tried.
It's like trying to squeeze blood from a rock.
I edit my posts a lot.
https://linustechtips.com/topic/868167-help/#findComment-10774778
I like this^^^^
Case: Lian-Li PC-011 Dynamic  CPUi7-7700k (4.8ghz) CPU Cooler: Corsair H100i V2 Case Fans: 5x ML120 RGB / 2x LL120  GPU: Aorus RTX 2080 Xtreme Motherboard: ASUS ROG STRIX Z270H RAM: 32GB Corsair Vengeance RGB Pro DDR4 (3200mhz) Storage: 2x 1TB SG Barracuda, 128gb BiWin M.2 SSD PSU: Corsair RM650x OS: Windows 10
https://linustechtips.com/topic/868167-help/#findComment-10774785
insalling windows
So you were installing windows. These errors are quite rare during install.
Anyway, do you see a error code of any kind? Possibly something starting with 0x000...?
Also at what stage was the install at?
-アパゾ
https://linustechtips.com/topic/868167-help/#findComment-10774803
6 minutes ago, misterman said:
insalling windows
Can you show us a picture or an exact transcript of the error message? There are many different thread related errors you could be getting. Was there an error code?
https://linustechtips.com/topic/868167-help/#findComment-10774821
