Alright, so here is my first ever build. Pretty much what iv decided on. Open to thoughts, opinions, advice etc.
Please note the CPU & Motherboard, as well as case and RAM, are pretty much set in stone. The rest is subject to change and i had a few specific questions
#1. Should I get an ASUS Geforce GTX STRIX 1050 ti or an ASUS Dual GeForce GTX 1050 ti? Whats the verdict?
#2. Is my CPU cooler alright? Do you recommend something better? I'm looking for something RGB But cheap and efficient. hoping to use the saved money here on other components
#3. Is my PSU alright? Recommend me a better one if you think it fits, but keep in mind I am planning to upgrade my GPU at some point (to probably a 1070 ti or 1080 ti) as well as buy more ram and possibly a 1tb SATA 3 SSD to replace the 1tb HDD
Okay, Here we go with the components :
Component   Selection Base Promo Shipping Tax Price Where
CPU 51zkoInLSiL.jpg $287.89   Free two-day shipping with Amazon Prime   $287.89 Amazon   Buy
CPU Cooler c80d9ebfdc9ddaf3bd6b8423a98656af.256p.jpg $54.85       $54.85 OutletPC   Buy
Motherboard d5dbbdef5a869773980227ae3976a0ea.256p.jpg $189.99 -$40.00 $1.99   $151.98 Newegg   Buy
$40.00 mail-in rebate
Memory 41SYlOnZ4qL.jpg $229.99   FREE   $229.99 Newegg   Buy
  Add Additional Memory
Storage 05c84a7f2b020b4efe1b7b736b9eefd0.256p.jpg $127.89       $127.89 OutletPC   Buy
  31AXpu3yaTL.jpg $39.88   FREE   $39.88 Other World Computing   Buy
  Add Additional Storage
Video Card 51VIqTTZ4xL.jpg $229.99   Free two-day shipping with Amazon Prime   $229.99 Amazon   Buy
Case 0e880ab3187d9fc986d6ad4cddbdbfc7.256p.jpg $52.89       $52.89 OutletPC   Buy
Power Supply 5ccdecd73f9b346ebf46d2845dc57ac2.256p.jpg $84.99   $4.99   $89.98 Newegg   Buy
P.S : Ignore Prices, i will not be buying from PC PartPicker and i will be getting much better deals elsewhere so prices of like the GPU and PSU listed above are irrelevant. CPU/MOBO/Case already bought, and much cheap than listen price. Just letting you know incase listed prices affect build judgement as i saw some were way higher
Also keep in mind the white/blue/black theme im kinda going for. mainly just white/clearish and blue. so you know lol
https://linustechtips.com/topic/867997-first-build-final-analysis/
7th gen is the worst deal now, since Ryzen and 8th gen sandwiched it from value and performance standpoint.
Z370 needed for 8th gen
H7 is too weak for an overclockable 8th gen chip. If it's a locked 8th gen then might as well use the stock cooler.
SATA SSDs are only a tiny bit slower than an NVMe drive when it comes to being a boot drive, but cost much less
For a gaming build you should spend around 40-50% of budget on the graphics card. This build is completely unbalanced because the graphics card is too weak and will limit the CPU's performance (eve in terms of 7700k, more so with 8th gen i5 and i7).
Desktop benching:
Like i said, i know that there are better cpu options and i could of went with 8th gen. BUT the cpu is ALREADY SET IN STONE. So i will make it work, Just looking for opinions on the entire thing as is right now, and im trying to stick to a budget GPU for now and ugprade later on. If i could get the 1080 ti right away i definitely would. im gonna use this as my daily driver even doing some photoshop work etc in addition to a bit of gaming. Nothing on like pro streamer level but you know
Why is the CPU set in stone? It's literally the same chip with more cores
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Nvm just read bottom
Full Specs
Helios EVO (Main):
Delta - Laptop
Get a different 1050 Ti if it's above $150 at the place where you get it, change PSU
Full Specs
Helios EVO (Main):
Delta - Laptop
Oh i definitely wont pay more than $160 for the 1050 Ti, and also what psu do u recommend? lower wattage? same 650w? any recommended brands?
FOCUS Plus Gold 750W is somehow $60 right now at newegg.com
550W is $54
Full Specs
Helios EVO (Main):
Delta - Laptop
For future's sake 8th gen or Ryzen is still better, even with mid-range CPUs so you can upgrade without changing the mobo.
If you arent using this graphics card for that long (like, a year and a half?) then getting something used that's not too old. At $150 it's hard to beat the 970 in terms of value. Even if you want the 10-series with warranty there are 1060 3gb at also $150, or 1050ti at lower than $120.
Desktop benching:
 Wow, id love a 1060 3gb for $150. I havent been able to find any good deal like that tho, and as for used parts not sure where i can purhcase them
