Controlling Fan Speed w/ Software
Solved by LogicalDrm,
Asus has excellent fan controls. You can control both 3pin or PWM fans with it. If you need more fans than there are headers, you need to get splitters. Pick either 3pin or PWM according to what fans you are going to use. You can't mix different control styles on same header. Each mobo header can power 2-4 fans. Depending on how many amps fans need, header supplies 1A.
6
popularlion ·
Posted in Troubleshooting4 -
2
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
R_public ·
Posted in Networking16
