I have a hackintosh (specs in signature) that works fawlessly, and I like the experience of MacOS/Mac OS X on a portable machine, so is there a way to use my hackintosh from my laptop with little lag? My laptop is pretty low resolution (1366x768), so it's not too many pixels to push. Thanks.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/866904-mac-to-pc/
If you are in the same network performance might be just alright but if you plan on remote accessing you rmachine if you are away from home it is gonna get laggy af. Still the experience is not going to be nearly as good and smooth as a native osx system on your laptop.
I mean just try it with teamviewer. Free and easy + quick to set up.
Folding stats
Vigilo Confido
https://linustechtips.com/topic/866904-mac-to-pc/#findComment-10762935
11 minutes ago, JDK319 said:
You could use Virtualbox
That's not what I was asking. I was asking if there was a way to connect to my existing Mac from a Windows computer.
Main System: Phobos
https://linustechtips.com/topic/866904-mac-to-pc/#findComment-10762975
3 minutes ago, CUDA_Cores said:
Only way to do that is with some sort of remote software like teamviewer. But as noted by @Nicnac your latency will be very high over a network. Especially from far away.
is the latency due to windows accessing a mac or just due to distance? im asking because over thanksgiving, i had to access my desktop from my laptop (using my iphones wifi tethering option) and i was able to work negligible lag. hung up just a couple of times over a 2 hour session. i didnt try a game or anything, so if thats what o/p is asking about, i withdraw myself from this conversation.
edit: i was about 300 miles from my desktop
https://linustechtips.com/topic/866904-mac-to-pc/#findComment-10763001
it all depends on your network speed at home and where you are accessing it. That's is. However even high-speed networks can experience lag at times. For games Teamviewer just won't even properly transmit anything from my experience.
Folding stats
Vigilo Confido
https://linustechtips.com/topic/866904-mac-to-pc/#findComment-10763009
used to be a tool under netsh ras called appletalk for network communications between windows and apple
not sure if its still there though
https://linustechtips.com/topic/866904-mac-to-pc/#findComment-10763490
The latency comes purely due to the speeds and distance. Speeds indicate, how much data you can send through. If the speeds are low, you won't be able to display images quick enough because they don't arrive quick enough. Distance matters, as it indicates how much time it takes for packets to travel the distance.
Don't expect to get a playable experience though.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/866904-mac-to-pc/#findComment-10770142
They might have been referring to virtualising the hackintosh and putting it onto the laptop. I've done this.
Although obviously you'll have 2 hackintosh machine's then which I guess isn't practical so I guess Teamviewer is the most likely option.
Probably gaming or helping technophobes with tech...
https://linustechtips.com/topic/866904-mac-to-pc/#findComment-10770143
