HP Folio 9480m
Attempting to run KillDisk to erase a HDD. Booted to disk as normal
"tarting Windows 98..." Normal
"A:\>"
Typed "killdisk" which normally gets me to the killdisk environment which allows me to select the drive I need to wipe..
Instead when I typed "killdisk" it came up with "Divide error"
Seems as if I can use some commands, DIR seemed to still work and "KILLDISK EXE" was available attempted "start "KILLDISK EXE"" and "start "KILLDISK.EXE"" which came up to "Bad command or file name."
Anyways not 100% on what to do next. If anyone has any ideas or advice they will all be appreciated. :)
https://linustechtips.com/topic/866857-killdisk-issues/
