Last week, this thing was working fine. It posted and booted to windows. Then I got an HDD, a fan hub, and two fans. For whatever reason, the PC won't turn on at all.
PCPartPicker part list: https://pcpartpicker.com/list/XBmnZ8
Price breakdown by merchant: https://pcpartpicker.com/list/XBmnZ8/by_merchant/
CPU: AMD - A8-5500 3.2GHz Quad-Core Processor  (Purchased For $0.00)
Thermal Compound: CRYORIG - CP7 4g Thermal Paste  (Purchased For $0.00)
Motherboard: ASRock - A88M-G/3.1 Micro ATX FM2+ Motherboard  (Purchased For $70.03)
Memory: Mushkin - Essentials 4GB (2 x 2GB) DDR3-1333 Memory  (Purchased For $0.00)
Memory: Patriot - Signature 8GB (2 x 4GB) DDR3-1600 Memory  (Purchased For $0.00)
Video Card: EVGA - GeForce GTX 750 Ti 2GB Video Card  (Purchased For $0.00)
Case: Cooler Master - Elite 430 ATX Mid Tower Case  (Purchased For $0.00)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (Purchased For $0.00)
Optical Drive: HP - DVD1265I DVD/CD Writer  (Purchased For $0.00)
Case Fan: Corsair - Air Series White 2 pack 52.2 CFM  120mm Fan  (Purchased For $18.56)
Case Fan: Corsair - CO-9050017-WLED 66.4 CFM  140mm Fan  (Purchased For $14.59)
Keyboard: HP - K1500 Wired Standard Keyboard  (Purchased For $10.24)
Other: Seagate 1TB Barracuda Sata 6GB/s 128MB Cache 2.5-Inch 7mm Internal Bare/OEM Hard Drive (ST1000LM048)  (Purchased For $43.00)
Other: CRJ Blackout All Black 5 Way PWM Fan Hub Splitter  (Purchased For $7.99)
Other: Aigo, Halo LED 120mm 12cm PC CPU Computer Case Cooling Neon Quite Clear Fan Mod 4 Pin/3 Pin (Purple)  (Purchased For $6.99)
Other: Enokay 120mm Black Fan Grill / Guard with screws (2 pack)+ 8 Pieces screws ($7.49)
Total: $178.89
Generated by PCPartPicker 2017-11-29 00:16 EST-0500
There's the build as of right now. Everything is connected properly. I even tried connecting another PSU that is known to work, and nothing.
The only thing that happens is that the PSU fan spins for a brief moment when the power button is hit, but it won't do it again unless you turn the PSU off, press the on switch, turn it on and press the on switch again.
Did the motherboard die, or is there something else at play here?
AX1600i owner. https://docs.google.com/spreadsheets/d/1_GMev0EwK37J3zZL98zIqF-OSBuHlFEHmrc_SPuYsjs/edit?usp=sharing My WIP Power Supply Guide.
https://linustechtips.com/topic/866704-computer-not-getting-any-power/
Just now, Gamerguy207 said:
Did you pay your bills?
Did you check the breakers?
Did Mom tamper with stuff again?
xD
why do I keep myself living :(
Electricity is fine :P
And breakers are fine. My other PC works and it draws more power. :P
Power surge fry mobo? That’s the only thing I could think of is a problem with the mobo or maybe a cable short?!?
I dunno. I only got the motherboard about two weeks ago. So, I can just RMA it. How is AsRock with their customer support?
Stuff I’ve heard is it’s good customer stuff btw do you know about the motherboard paper clip trick?
I've tried bridging the power pins with a screwdriver and it did nothing.
Did you buy from iBUYPOWER?
sorry I had to.
Have you tried testing your PSU with your other machines? Then test the PSUs from those machines in your current one.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Figured it out. Apparently, it happens when I plug in the fan hub. Maybe the fan hub is causing a short? Oh well. Going to buy a fan controller instead.
