Hello everyone,
I am having trouble with my HP PC.
I am trying to restore the default factory cpu clock setting for my pc.
I don't remember but I think I used AMD overdrive to enable turbo core mode for the cpu. For the past few hours I have been trying to get my clock settings in AMD Overdrive to stick, but when I shutdown my pc and then turn it back on the clock speed for the cpu stays the same at 3.7Ghz. I want to stay at 3.5Ghz.
Yes I know I should have not used amd overdrive to oc my cpu but im too late, I messed up my pc.  I have tried to tick the settings in preferences to use the last setting after boot but no luck.
I tried running AOD in administrator mode and clicking APPLY. I have tried to click set to default but no luck.
Tried turning off turbo core mode and click apply and okay but still doesn't save after shutdown.
Tried disabling the aod services.
Tried uninstalling Amd Overdrive.
Tried uninstalling catalyst control center.
Still after reboot the clock speed would be 3.7Ghz.
Maybe changing power plan setting?
It's on high performance mode.
Is that making it enable turbo core?
One thing I have not tried was to reset my bios by removing the cmos battery.
Will this work to reset the oc settings.
Or is my pc forced to use turbocore mode?
Btw there is no overclock settings in the bios. There is no way for me to change the cpu clock speed in the bios.
PC specs
HP envy h8-1414
OEM motherboard
Amd fx-6120
Gtx 1050
10Gb ram
https://linustechtips.com/topic/866375-hp-oem-amd-restoring-default-clock-speed/
