Just now, VinZie said:
I got an error: Windows 82 doesn't work anymore
Well that isn't fan related. What mobo and fans you are using anyway, and is CPU fan connected to CPU header?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/864906-fans/#findComment-10744554
https://linustechtips.com/topic/864906-fans/#findComment-10744555
1 minute ago, LoGiCalDrm said:
Thats splitter or extension. Why even post it?
It's a splitter but it was just the first one on overclockers. Plus it's pretty.
Look at the picture, one input, 3 outputs.
CPU: R5 3600 @ 4.4 GHz
RAM: 16GB DDR4 @ 3200 MHz
GPU: RTX 2080 Super
https://linustechtips.com/topic/864906-fans/#findComment-10744558
1 minute ago, VinZie said:
Oh shit, I forgot to plugin my CPU
Well, there''s your problem :D CPU overheating.
Still don't understand why post it. Question was how to connect 3pin fans to 4pin headers.
https://linustechtips.com/topic/864906-fans/#findComment-10744566
Well it's the same as what I used to fix the same problem so surely it's worth a post?
GPU: RTX 2080 Super
https://linustechtips.com/topic/864906-fans/#findComment-10744572
10 minutes ago, akash123 said:
Pc boots with liquid cooler as the cpu cooler but fans nothing. I have 3 case fans I want to use
They don't work in any header? And pump is working?
https://linustechtips.com/topic/864906-fans/#findComment-10744594
1 hour ago, akash123 said:
So having tried the fans individually in the mobo says fan header they all work so is he hub really faulty?
Plug the hub into your cpu_fan or another 4pin pwm header.
Is there a cable for the hub that connects to the psu? It should come with one and it's what provides power to the fans.
You need to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
https://linustechtips.com/topic/864906-fans/#findComment-10745876
