Hi I had a prebuild system for a long time and now I decided to upgrade, this is the build right now https://pcpartpicker.com/list/Jbm2pb (I already have the SSD) + an 2TB HDD im gonna salvage and a DVD drive, the case is gonna be Regnum RG1W Pure Black. I want to use it for 4K gaming and I wanna try streaming and Im thinking about buying VR in the future. So I want to ask if there isnt a part Im including right now that would be bad or something. Im right on my budget right now.
https://linustechtips.com/topic/864624-my-first-pc/
Just now, Himommies said:
it dosen't have a price attached to it
whats your budget
My budget should be equal to 1250 USD (31000 CZK), but in my country the prices are mostly meh, so thats that, https://www.czc.cz/amcm3ra9dqgc08remu0qmgnb73/seznam thats the shopping list in my country shop (for the prices).
https://linustechtips.com/topic/864624-my-first-pc/#findComment-10742447
Do you already have the 4k display? If not is Vega at it's MSRP where you are? As free-sync displays are always going to be cheaper than G-sync ones.
If you were going to get a better board you'd want an ASUS PRIME PRO X370
https://linustechtips.com/topic/864624-my-first-pc/#findComment-10742505
Better board is saddly over budget, Vega has the same cost as 1080 (1080 is better than vega 64 right?)
https://linustechtips.com/topic/864624-my-first-pc/#findComment-10742558
Do you already the 4k display? if not Free-sync 4k displays are way cheaper than G-sync 4k displays
the cards are about equal, and After market vega cards should be out soon.
If Vega 56 is even cheaper get that, and take a few minutes to flash the BIOS to 64. then get the nicer motherboard.
https://linustechtips.com/topic/864624-my-first-pc/#findComment-10742567
The thing is we still have the black friday sales here until sunday so I have to buy it until then or Ill be over my budget, to be honest about the 4k display we have home theater with 4k projector so I want to hook it up to that, the vega 56 is like 20 bucks cheaper than 64 so it wont be enough for better mobo
https://linustechtips.com/topic/864624-my-first-pc/#findComment-10742590
45 minutes ago, Akol said:
Then I dunno, Vega is pretty nice overall, but using a projector a monitor is likely to be a bad experience for gaming
https://linustechtips.com/topic/864624-my-first-pc/#findComment-10742743
I want to use the projector for slow paced games (Like XCOM or Civ etc.) and normal monitor (1080p) for fast paced ones. And if the projector will be sh**ty Ill just wont use it :)
Btw: thanks for the advices
https://linustechtips.com/topic/864624-my-first-pc/#findComment-10742765
3 minutes ago, Akol said:
Then possibly go for Vega for free-sync savings if you're ever going to upgrade your display
https://linustechtips.com/topic/864624-my-first-pc/#findComment-10742778
